Originally posted by Baileylsd
I would also like a mod-chip for my ps2
is it bad for them??
like will it not work as well?
no its not bad at all bro, cant harm anything unless it aint installed properly, but i let my customers watch me do it, compare my installations to the technicians in the US that post photos and i guarantee mine's better :D
and it will definitely work and if it doesnt you have the given right to punch me in the temple :D
https://www.sau.com.au/forums/topic/21448--/#findComment-453911
Originally posted by DJ_L3ThAL
darky... my house in tullamarine, and NO im not picking u up :D
err... npz
tullamarine is alright..
do u have a website or something.. so i can check out the stuff you have? coz there are tons of different chips available.. and i dont know which to get :D
https://www.sau.com.au/forums/topic/21448--/#findComment-454023
apache: try and die :D... and depends on the model (SCPH) number form the back of your console and which chip you want, currently im recommending the messiah 2 for people who just want to play copied games and want the bets quality, the magic 3.1 ultra for people who just want to play games and wanna save about $25 and dont mind some cd-r copies not working (they are good if u plan to play dvd-r only.. which is recommended to keep the laser life at its optimal lifespan) and the DMS 3 for people who want what the messiah does + be able to upgrade the chip in the future easily from free downloads from manufacturere's site (www.dms3.com) burn onto a cd-r strick in ps2 and vwala its updated firmware and also multiregion dvd movies and the abiolity to load programs downloaded for the PS2 ie. mp3 players and vcd players etc) when they are released onto the internet in tyhe future (its already happening)
the dms is much more expensive though
darky... as above to decide which chip... and the websites for the 3 chips im offering at the moment are
www.dms3.com
www.messiah2.com
www.china-magic.com
https://www.sau.com.au/forums/topic/21448--/#findComment-454136
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
    • More photos are up, and the price has been dropped to $16,000. It's just had a service and a new 12V battery, too.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
