Just brought my self a R34 GT-V, (Imported, waiting for compliance)
I have found out some info on the GT-V, but nothing concrete, like a spec sheet or something,
Just want to know if anyone has one of these or knows the specifications on the GT-V.
The jist of it is the GT-V is a NA sitting on a GT-T chassie, same suspension, same brakes, hicas, viscous LSD. how accurate is this?
https://www.sau.com.au/forums/topic/214496-r34-gt-v/
The GT-V has the same brakes and suspension as the GTT. The suspension wont make much of a difference because most people swap that anyway, but the brakes are a good upgrade.
The interior is still the na setup obviously (no centre gauges)
I doubt it has the GTT gearbox, most likely just the stock na box
Edited by R34GTFOUR
https://www.sau.com.au/forums/topic/214496-r34-gt-v/#findComment-3788532
Auto box, not sure if there is a difference between na autos and turbos
With the suspension, does this mean I can upgrade the suspension using GT-T parts or even R34 GT-R suspension - something like http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...E:L:LCA:AU:1123
Edited by Grunta
https://www.sau.com.au/forums/topic/214496-r34-gt-v/#findComment-3788561
Almost 100% just GTT
GTR's use diff lower mounting points at the rear and have diffrent sprint rates at the front because of the extra weight of the driveshaft/diff/props
Just do a search (top right hand just under the SAU banner, click search, then adavanced search.. type in what ever and scroll down and click on the "suspention" section so it only searches that) in the suspention section.. has been covered many-a-time
https://www.sau.com.au/forums/topic/214496-r34-gt-v/#findComment-3789249
I have just bought a R34 GT-V as said above 100% GTT minus the turbo. Mine is a 4 door 5 speed in Black Pearl, still very much stock [have to save some money before I have a play with it]. check out the link below.
       http://www.skylinesaustralia.com/forums/Gt-Owners-t204323.html
https://www.sau.com.au/forums/topic/214496-r34-gt-v/#findComment-3790788
Correct, the GT-V does not have the GTT box It has a variant of the R32 RB20DET gearbox ( with some subtle differences like electronic speedo drive, different shaped gearstick etc ).
GTV.pdf
  • Like 1
https://www.sau.com.au/forums/topic/214496-r34-gt-v/#findComment-3801396
Everything I have seen has said the GT-V came out in 2000, which is in-correct as my GT-V I brought was built in March 1999, (checked the VIN on Nissan Fast)
So I wonder what if anything is different about mine than the ones built in 2000+
It probably wouldnt have any difference if it was built late in 99, but March is very early, I got Xenons, as I saw them when I went and had a look at my car before it gets sent off to get a compliance plate. (hopefully they leave the xenons in)
https://www.sau.com.au/forums/topic/214496-r34-gt-v/#findComment-3806798
From what I can gather the GT-V is a 2000 production model but was released in late '99. The post 2000 release models had the S2 updates e.g. 2 tone gear knob/steering wheel, white backed speedo/rpm gauges on the dash, the (slightly) ugly front bar and probably a few more things I'm not aware of. This confused me for a little while but you're right, GT-V was first released in 1999.
P.S. If the workshop do their job they won't leave the xenons in :)
https://www.sau.com.au/forums/topic/214496-r34-gt-v/#findComment-3807287
P.S. If the workshop do their job they won't leave the xenons in :D
yep true, they took mine out the bastards...
i've got the headlights that say xenons, but no xenon bulbs haha
i never understood why they took them out?? plenty of cars have xenons now days, whats the deal?
https://www.sau.com.au/forums/topic/214496-r34-gt-v/#findComment-3813052
I found this site the other day, it cover series2 skyline's. But info and spec seem to be the same as series1. you will need a web page translater such Free Web Translator
http://history.nissan.co.jp/SKYLINE/R34/0008/index.html
Free Web Translator
http://www.worldlingo.com/en/websites/url_translator.html
cheers :)
https://www.sau.com.au/forums/topic/214496-r34-gt-v/#findComment-3815661
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
