Item: Spalding basketball stand hoop backboard thingy
Age: A few years old
Condition: Not too bad. Its been out in the weather since new, so its a bit....weathered? but its sturdy, and looks fine.
Price: 50 dorra FREE !!!
Contact: PM me or post here
Comments: If anyone is interested, I will pull it apart and give it a clean before pick up. It wont fit in your skyline boot, so bring a bigger car.
the bbq doesnt come with it :(
Edited by Munkyb0y
ok. i'm currently taking offers. nothing under $0.00 will be considered. will consider swaps for such things as a hand full of air.
-after a quick sale
-going overseas
-work just gave me a new company Basketball Stand Hoop Backboard Thingy
-got a baby on the way
-need deposit for a house
-need cash for hookers and booze
Edited by Munkyb0y
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
