hey guys im getting a weird ticking noise that's proportional to the engine revs from the turbo side of the engine bay at low revs (from 1.5k to about 3k... not sure if it goes away at 3k or if its just too noisy, ie. pod suction/turbo spooling for me to hear it) and im getting worried i really dunno wtf is going on, im going to ice performance tomorrow to get it checked but was wondering if its a known thing or something so i KNOW to check something before i drive for 50mins over there, hopefully someone knows what im talking about
my car + mods are:
r33 gtst (95)
full zorst, pod & FMIC
profec b spec 2 EBC
powerfc w/hand controller
cars running at about 10.5-11 psi (0.7-0.75bar)
im scared something is really wrong last thing i want is a dead engine/turbo... oh and the car is still making perfect boost (is pinging a little bit but i think timing just needs a bit of retardation to fix that up)
https://www.sau.com.au/forums/topic/21454-turbo-ticking-noise/
Guest RedLineGTR
depends what the guys at ICE say thier is also a joint near chadstone called ATP they specialize in just turbos maybe they can give you some other feedback if ICE cant help ya which i doubt. I gotta checkout my car as well gonna head down to ICE probably wed at the latest finish work early.
i just let it wamr up to normal temp and then turned it off, removed dipstick, wiped it clean replaced it and waited 10seconds then took it out and it was sitting just underneath the L point on the dipstick, im assuming thats the way to check the oil and if that's the case then im totally outta oil, just put 500ML of new oil i had spare in running that through,, then will turn off and se if it goes up a bit, if thats the case that there wasnt oil then that explains the ticking... can i have done much damage ? and how the **** would have the car eaten up that oil ? what are the causes of a car eating oil ? coz it definnitely did not drip outt somewhere coz there was no oil marks whereever i parked!
:D
you only check your transmission oil straight after a good run, when it is hot.
Engine all should be checked when stone cold.
Sorry can't really help ya with ticking noise :D
But can the ticking be the boost selanoid (sp?) switching open/shut to controll thr boost?
Are you sure it is your turbo and not just your injectors or lifters? As after a hard dyno tune, a lifter may get a little noisy. Mine did, and went away after a long cruise.
Check your intercooler pipes for excessive oil residue. Really hope you don't find any, as it will indicate a worn eng./turbo (especially at a lowish boost level). May need to get an oil/air separator if that's the case.
its deifnitely not the boost controller as i turned it off :D been running stock boost for safety since i heard it
my oil sems very low.. will check tomorrow morning
god i hope there's nothing majorly wrong :D
will check intercooler piping however if its just low oil ill fill it up tomorrow and cruise to ice and let the pro's handle it
and redline.. i put in 4.5Ltrs approx
Well with nearly zero oil in there i think is probably the noise..
He can probably literally here the valves opening and closing or cams turning around because there is not enough lubrication in there.. not good whatever it is!
Hopefully the engine is all a-okay, but if its burned a whole 4L or so of oil in only a couple of thousand km's something not too good is going on.
You definately do hear ticking like that with low oil.
Did someone steal your expensive oil after watching you change it and get underneath with a spaner and collect your oil? - haha
Do that check oil level in the morning when cold.
Check your muffler - is it wet with oil slick?
you'd better fill your oil up again before driving it further!
check your oil pressure too - post that.
If its hot the oil would drain to sump sufficiently fast to get a reading accurate enough after half an hour. However if the oil filter is blocked you might have to take the reading while cold.
Blow by is a cause of oil consumption but usually its worse at higher boost. Blow by gets worse as the piston rings get worn.
hmm ok well i spoke to ice and told him the level of ym oil he saiod thats ok there's enough oil for it not do any worryful damage but its still a problem that needs adressing, ive got about half a gauge reading on oil nowb y topping up with leftover oil i had form last change (clean new stuff) and what ill do is fill it full before i hike to ice, gunna try it tonight to see if the clicking is gone, but nevertheless i wanna kno where my $60 per bottle mobil 1 has gone lol
maybe a catch can could help with this problem
so gortdon its chewed only a couple litres ice said if its at the level i quoted them
Sounds like you done a turbo seal dude, fairly common i'm afraid, often goes un noticed tho. I was going to say if you have a bigger turbo on it that'd be why cos of the design of some bigger turbos they sound like they are ticking but is acutally the exhaust sound resonating through the bigger blades, but only on some turbos. But def check you seal, could also be the reason why you are losing oil if it has damaged the bearing case and thrust bearing you could be using oil, check the inside of your cooler piping to see if its oily cos then you'll know you got oil in your turbo.
    • So yes. All of them. Something like 98% of all fuel in the USA has 10% ethanol: https://afdc.energy.gov/fuels/ethanol-fuel-basics It's labelled as like, AKI, 87, 91, 93 with an E10 or E5 or E15 label on the pump. At a certain point, it's not just "E10" instead of 91. It is 91, 95, 98, and all of them have 10% Ethanol in them. You can also get E85 and E30 which is why you do see some people rolling around with E30 tunes in them.
    • Thanks for the response. This is an 04 EP3 Type R. JDM spec. Fairly certain they're just basic BC racing coils. I do plan to keep as the ride quality on stock I've been told is pretty meh given Sydney roads. If I were to go down that avenue, does NSW require them to be a certain spec (close to original) etc?
    • Should have asked what is the car?
    • I've had two super conflicting experiences with blue slips. My 30 year old E39 waltzed through with no issues but my brother in law was knocked back on 12 y/o 3 series due to wiper blades and some cracking in a control arm bush.  What kind of coil overs? Do you want to keep them after?  If it was me I'd get some dirt cheap shocks and springs from eBay or scumtree. Not ideal but will get you over the line and might even be less than $1k.
    • Hey guys,  Way back when (about 15yrs plus), I picked up a beautiful set of Tein 'Super Racing Spec Circuit Master RE' coilovers from Russman. I have legit never fitted them to my car, as it was garaged indefinitely while i bought a house Yada Yada. They look brand new! Anyway its time to pick up where I left off, and have started doing some khanacross and am booked in for a hill climb next month. The car has some hard af Nismo shocks in ATM, which has me wanting to upgrade again, and now I am left wondering if it's worth having these teins rebuilt? I think they where an ok shock back then, but how do they compare to what's on the market now?  Shockworks/mca are 2800+, and I am sure they are great. But if I can have these rebuilt and be better than, say, a set of bc's for around the cost of bc's, I would be happy with the performance v cost trade off.  If they are considered outdated and rubbish these days, so be it, I'll put them on the shelf and be happy to look at the pretty green colour while I save for the SW/MCA option. Grateful for your thoughts on the matter, and suggestions on who could do the rebuild if it's a worthwhile pursuit.  cheers, Rowdy.
