Hi guys,
First up I own a 98 R33 S2 GTS25T Skyline with the following mods:
HKS Cat back exhaust
De-cated
Pod Filter
GFB Hybrid BOV
I've noticed a oily smell incabin... partically when i'm slowing down or have just been giving it a bit of stick. I changed the oil about 4,000km's ago with Shell Helix 5w40. This problem has only seemed to arise since I've de-cated the exhaust?
Any ideas what it could be?
https://www.sau.com.au/forums/topic/214551-r33-s2-oily-smell-incabin/
Check that you haven't caused any exhaust leaks during your decating process (did you replace gaskets) Do this by letting the system cool down completely and rub 50/50 dishwashing liquid and water over the flanges. Then start the car and look for bubbles...
Yeah, I'm not sure about the gaskets - An exhaust guy fabbed it up and installed it.
I guess I'll jack my car up tonight and unbolt it and have a look.
Cheers mate, also I was looking at some Fuchs 5w40 oil, whats that like for a RB25DET?
Edited by dekodE_
FWIW there are heavy penalties for removing emissions equipment (ie decat) for a car that's used on the road. A high flow (magic cat/metal cat/catco) style cat shouldnt restrict power at all on your setup, and will reduce the smell and the amount of black crap that will end up on your rear bar.
you may also have a leaking rocker cover gasket. usually passenger side. the oil gets onto the block, and when boosting around, the higher block temps burn the oil and you can smell it quite a bit.
what the f is FWIW?
lol ...for what its worth
Edited by Munkyb0y
Fuchs is fuching good stuff! :) Pricey but worth it.
Sweet, I think its about $79 for 5L which isn't too bad. I might grab some tommorrow.
Had a look in the engine bay for any leaks, and tried to "sniff for oil" couldn't find anything.
Then I took the car out for a spin, It was only really noticeable once I had come to a stop (So i'm still thinking it's an exhaust leak as first suggested, guess I'll jack the car up tommorrow and check it out.
My current oil level hasn't changed, and my car doesn't smoke at all, even on boost... :laugh:
Edited by dekodE_
The rubber seal around base of your gear shifter might be split. That will give off an oily smell in the cabin.
exactly what i was goin to say..my car had a short shifter in it when i bought it but i didnt like it so i bought a gtr shifter to replace it..when i went to take out the short shifter i found the previous owner had put a tea towel around it to stop oil spiting out which stoped the smell getting to the cabin and the short shifter had no seal..so i had to buy a seal from nissan when i put the gtr shifter in and i removed the tea towel..i had an oily smell in my cabin for round 2 weeks but its gone now :D
Interesting idea's being thrown about when OP said...
...This problem has only seemed to arise since I've de-cated the exhaust?...
Every cat'less car i know has a particular smell to it. Hard to describe. When idling, and a breeze blows the fumes into the cabin, smells kinda oily i guess; sure its not just that?
If your sure it only started when you ripped the catback off, smashed the china out of the cat and shlaped it back on... then start there first.
LoL @ Luciano_GTST.... Google will tell you all abbreviations ;)
Edited by GeeTR
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
