Hey put a rb20 turbo setup on my rb25 and got gtr injectors and dyno tuned.
Made 150kw but was missing got new plugs and drives mint.
But when it idles it is either at 1100 or 2000.
It also uses so much fuel $25 gets me 40km and it seems to be getting less.
I've taken apart the aac valve and cleaned that but it makes it better for a little while.
Cleaned afm and have wasted spark setup.
Any ideas
https://www.sau.com.au/forums/topic/214556-bad-fuel-economy-and-idle-probablm/
uh? so you have a r32 with rb25 motor?
You got correct ecu in there? If so which one?
For better fuel economy change 02 sensors, put the correct heat range plugs, and clean your afm.
But if you saying that you only get 40kms out of 25bucks, then you got a serious problem.
You sure theres no leak in the fuel tank?
Coz 25bucks worth of fuel and you get 40kms is BADDDDDDDDDDDD
OR could it be that your dash speedo thingy is broken?
Edited by siddr20
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
