Hey Guys,
I need your help...
In Jan of this year, I had my stock R34 (auto) dynoed. Output was 134 kw at the wheels. Seemed pretty standard. Today I had it dynoed again to find out what gains have been achieved after the following mods:
HKS dump pipe ($576)
HKS front pipe ($300+)
High Flow Cat ($200+)
3.5 HKS Cat Back ($900 second hand)
K&N panel filter ($126)
Turbosmart Dual Stage Boost Controller ($270+)
The result...nil gains at all.
We were trying to come up with the optimum boost setting. The stock boost reading on the dyno indicated between approx 6.9 to 7.2 psi. Air fuel mixture read 10.0. When the boost was increased to 8 psi, power suddenly dropped to less than 100 kw. I've spent close to $2,500 so far.
Could someone please point me in the right direction. What could have gone wrong?
https://www.sau.com.au/forums/topic/21457-r34-woes/
Yes, it's definitely fuel cut. Also the mixture is pretty bad to start with at 10:1, it should be at least into the 11's. The mods you have done aren't in vain though (although your exhaust system was a little expensive), once you get the boost and fuel cut sorted out you will get an extra 50kw on those figures easy.
https://www.sau.com.au/forums/topic/21457-r34-woes/#findComment-453974
He said his car is automatic. PowerFC doesn't work with Automatic cars. So far Apexi only made one version for the auto, which is for the Supra only, due to many TT Supra in Japan are autos.
If you want PowerFC, get your R34 converted to a manual, or sell it and buy a manual R34. Alternatively Buddy Club released a piggy back computer for auto cars, but dunno who can tune it here in Australia.
Originally posted by R34GTT-R
Ecu is retarding the shit out of it.R34 ecu apparently really sensitive and dont like boost increase as much as previous models.i would start saving for PFC.
https://www.sau.com.au/forums/topic/21457-r34-woes/#findComment-454053
Dunno abt e-manage, but there was another thread discussing abt e-manage side effect of melting the coil pack in automatic Nissan cars. Didn't happen with Toyota cars, so apparently owning an automatic Nissan performance car could b a real pain if u want to modify it to a certain level...
Do a search on e-manage in this forum... cheers.
https://www.sau.com.au/forums/topic/21457-r34-woes/#findComment-454133
    • This has been covered a bazillion times but google wet boiling point vs dry. Motul is only good when it's fresh, once it absorbs moisture it gets pretty average very quickly. So as above, make sure you change it if you're going racing. I run the Endless brake fluid in mind, but only because a mate is a distributor and it's cheap. It's not quite as good as SRF but I'm running 380mm rotors on a Skyline so it's not like they get hot.
    • That's the thing, they still add it and it makes fuel cheaper, implying adding 10% of it drops the cost of 91 by what, 5c a liter? I remember when it was barely half the price of 98. Because you know, 85% of what is in the fuel is way cheaper than 91 fuel is by volume.
    • Auto electricians that do repairs on automotive AC systems can source service kits. I don't know where they actually source them. I do know that there is one available for the R34 comp that I would need it for. If you have to pay someone to dismantle, clean and do needed repairs and fit kit contents, then you'd probably end up spending a good fraction of the cost of a new one. I would not be paying for that, because I would be doing it myself. My mechanic (bro-in-law) will happily source what is needed. Back in the day (like in the 80s and 90s), rebuilding an AC compressor was the standard approach, same as for starter motors, alternators, etc, because new replacements were v. expensive. After the China manufacturing boom and the rise of the disposable approach to everything, people just started throwing broken/worn stuff away and not rebuilding things.
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
