Be involved in a real race team! Pit crew volunteers needed!
On the topic of this, i thought this would be appropriate.......very funny stuff ........no one here is a Maori??? lol
Modena, Italy.
> >The Ferrari Formula 1 Team fired their entire pit crew yesterday. The
> >announcement followed Ferrari's decision to take advantage of the New
> >Zealand Government's "Work for the Dole" scheme - and to hire unemployed
> >Maori youths.
> >The decision to hire them was brought on by a recent television
documentary
> >on how Maori youths were able to remove a set of car wheels in less than
> >six seconds without proper equipment, whereas Ferrari's existing crew
can
> >only do it in eight seconds with the aid of millions of dollars worth of
> >high-tech gear.
> >This was thought to be an excellent yet bold move by Ferrari management.
> >As most races are won and lost in the pits, Ferrari would have an
advantage
> >over every other F1 team.
> >However, Ferrari got more than they bargained for, as during the Maori
pit
> >crew's first practice session, not only were they able to change all
four
> >wheels and tyres in under 6 seconds, but within 12 seconds they had
> >re-sprayed, re-badged, and sold the vehicle over to the McLaren Team for
> >four cases of Crown Lager, a gram of smack and a quick glimpse of David
> >Coulthard's bird in the shower
Ando
  • Replies 45
PranK,
Good luck dude I hope you find something soon. Being unemployed for 3 months myself, I know it's pretty tough out there in IT ATM.
What do you want to do for a job when you are ready to start again ?
Cheers,
Hi All,
Firstly, thanks to all that volunteered to help out with this. The promotors have, however, clarified what the "pit stops" will be....we just have to pit, remove a velro sash from the car, get back in and head off! So, no need to get a crew together to change the tyre, only cheering is required.
Everyone is still welcome to come along on the day, as well as the mighty daewoo 1 hour race, all the regular categories will be running as well.
And PranK, does this mean we can cruise before midnight now :O
Well, sash removing cheer squad, I havent got confirmation of the programme for the weekend yet (as usual), but we will be out there. There will be races on from 9am-5pm, we'll prolly be there a bit earlier for scruitineering.
We should have one of the corporate boxes (usually the end one), so I'll see you guys there.
BTW, for anyone who would like to get into racing, the organisers of the daewoo series are running this contest for a free season, its being run in 2 weeks:
http://www.skylinesaustralia.com/forums/sh...&threadid=22864
Well, we've got the times for the combined touring / daewoo races:
Sat: Qualifying: 10am, Race 1: 12.00
Sun: warm up: 8.30, Race 2 (1hr): 1pm
See y'all there :)
Well its was a good day out (apart from the small issue of remodelling the right front of the car :P
I'll be starting from 4th tomorrow, which has me in with a good chance.
I do actually still need another volunteer to help out tomorrow, we need someone to act as car controller when the jump out/jump in happens :P.
Whoever wants the job, I'll need you out there at 8am tomorrow so we can practice the stops during the warm up.
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
    • @Dose Pipe Sutututu I read your replies RE: R35 GTR MAFs, any ideal spots to put on? Obviously will need the adapter plate. Will be having a cross over intercooler fitted shortly, would putting it a bit before the TB be okay?
