Item: Spray Gun - SATAjet 3000 RP Digital (gun only) SOLD
Condition: As good as new
Price: $450
Contact: 0424 322 182
Comments: rrp $1000
Jetstream:
• Newly developed nozzle concept for even higher color match precision and homogeneous material distribution
• Wide and even fan for higher work speed
• Perfect for the application of base- and clear coats
• Even better surface quality for spotless finish
• Finest material atomization
• Ensures excellent painting results
Countdown: VOC-Compliant Equipment
• Suitable for all waterborne and solvent-based material
• Complies with all VOC regulations with regard to solvent reduction and material savings – for the sake of our environment
• Transfer efficiency rate > 65 %
• Low overspray atomization
Chrome Fever: High-Brilliance Gun for Brilliant Results
• Fully chrome-plated paint spray gun
• Chrome is wear-resistant and retains its value
• Chrome is corrosion-proof – even with waterborne materials
• Chrome is as valuable as gold – both visually and technically
• A well-balanced gun in state-of-the-art design
• Perfect ergonomics for fatigue-free work, e.g. optimized center of gravity, lower triggering forces
• Every step turns out just right: easy handling and operation
• Top class premium technology "Made in Germany"
• Easy cleaning and servicing
- Chrome-plated gun body
- Replaceable air distribution ring
• Self-adjusting packings
• Low-noise spray fan
Edited by HCR32_GTSt
https://www.sau.com.au/forums/topic/214589-spray-gun-for-sale-sold/
hey mate i use the iwata wb400 just wondering if u think that the sata jet is better if u could mate could u post sum pics i heard they got a big fan on them which the iwata lacks and wat size nozzel is it 1.3-1.4
Edited by fab34
i think the SATAjet is a better gun and the fan is big, which makes it easy to use... the nozzle is 1.4 ill get the pics up today hopefully
there has to be someone on here thats a spray painter n
needs a new gun?? this is a top of the line sata gun
i hardly used it, unless something important needed
to be painted... which was rare
i have one of these and they have total disrespect for material....although they really are a great tool for large stuff/full repaints ect....We paint motorbike parts so the iwata is better for us but if doing i full car job i use the sata....great price you got there...
yea its great for work on cars... as thats what i do. iwata's are great guns too.
even tho its a great price i havent had much interest yet which is a shame
i paid a little ova 1g for it and it hasnt been much at all coz i only used it for
special jobs
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
