Item: Spray Gun - SATAjet 3000 RP Digital (gun only) SOLD
Condition: As good as new
Price: $450
Contact: 0424 322 182
Comments: rrp $1000
Jetstream:
• Newly developed nozzle concept for even higher color match precision and homogeneous material distribution
• Wide and even fan for higher work speed
• Perfect for the application of base- and clear coats
• Even better surface quality for spotless finish
• Finest material atomization
• Ensures excellent painting results
Countdown: VOC-Compliant Equipment
• Suitable for all waterborne and solvent-based material
• Complies with all VOC regulations with regard to solvent reduction and material savings – for the sake of our environment
• Transfer efficiency rate > 65 %
• Low overspray atomization
Chrome Fever: High-Brilliance Gun for Brilliant Results
• Fully chrome-plated paint spray gun
• Chrome is wear-resistant and retains its value
• Chrome is corrosion-proof – even with waterborne materials
• Chrome is as valuable as gold – both visually and technically
• A well-balanced gun in state-of-the-art design
• Perfect ergonomics for fatigue-free work, e.g. optimized center of gravity, lower triggering forces
• Every step turns out just right: easy handling and operation
• Top class premium technology "Made in Germany"
• Easy cleaning and servicing
- Chrome-plated gun body
- Replaceable air distribution ring
• Self-adjusting packings
• Low-noise spray fan
Edited by HCR32_GTSt
https://www.sau.com.au/forums/topic/214589-spray-gun-for-sale-sold/
hey mate i use the iwata wb400 just wondering if u think that the sata jet is better if u could mate could u post sum pics i heard they got a big fan on them which the iwata lacks and wat size nozzel is it 1.3-1.4
Edited by fab34
i think the SATAjet is a better gun and the fan is big, which makes it easy to use... the nozzle is 1.4 ill get the pics up today hopefully
there has to be someone on here thats a spray painter n
needs a new gun?? this is a top of the line sata gun
i hardly used it, unless something important needed
to be painted... which was rare
i have one of these and they have total disrespect for material....although they really are a great tool for large stuff/full repaints ect....We paint motorbike parts so the iwata is better for us but if doing i full car job i use the sata....great price you got there...
yea its great for work on cars... as thats what i do. iwata's are great guns too.
even tho its a great price i havent had much interest yet which is a shame
i paid a little ova 1g for it and it hasnt been much at all coz i only used it for
special jobs
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
