alright i thought id add my 2c. i love BOTH, the R32 and the R33. I wish i could own both. I always admire them when i see them on the road. Hell i even get waved at in my 33 by drivers(32,33).
Iv driven both. The R32 seems more punch, due to the lack of torque as compared to the 33. The 33 has more weight however has more torque. Stock for stock tho, the 33 will win.
The 32 i feel gives you more driver feedback. Neither of them are slow. The 32 likes to rev out. the 33 doesnt NEED to rev out as it has more immediate torque. Down low, the R33 will take the cake anytime, anywhere, however the 32 closes the gap at the top of the rev range as it peaks then.
I love the shape of the 32. damm sexy!
  • Replies 165
Posted Images
It doesn't close the gap at the top end... I overlayed a mate of mine's 205rwkw R32 GTSt dyno plot with my 280rwkw dyno plot from the same dyno. The R32 was running equivalent mods to mine (bigger turbo, ECU, injectors etc) but with more boost. His lag was about the same, and if anywhere the gap "closed" in the midrange which is probably mostly to do with the larger amount of boost - my dyno plot actually pulled noticeable distance away from his one above 6000rpm. Despite the hype, in my experience when you go a bigger turbo etc on an RB25 they rev harder than RB20s too, and still don't need to.
But RB25s are for lazy drivers who dont want to work hard for their performance :D Dont get me started on RB30s!
R33 is simply the better car on paper. Problem is cars of this age are all so different with regards to mods and condition. Your friends RB20 may not be as well bolted together as your RB25...soooo many variables. Here is an example of my RB20 vs two RB25s. So it all depends on the particular cars you want to compare as to what your opinion will be
But RB25s are for lazy drivers who dont want to work hard for their performance :banana: Dont get me started on RB30s!
Haha I'm not sure if you are joking or not, I knew someone who had that honest opinion. If you went from your RB20 to an RB25, do you think you'd suddenly not try and milk everything it has to give? You've done an awesome job of making RB20s look better relative to its RB25/26 cousins than it should do - I credit you and your car setup more than the engine, makes me wonder how you'd go with a decent RB25 or 30 :)
The dyno plot you have used there doesn't really show anything, all I get from it is you have a different tyre speed vs revs to the other two cars and are probably running more boost. Australia, for heavens sake - get some hub dynos!!
If your talking lazy then EVERYONE who drives a Skyline is lazy taking the turbo option... what a bunch of cheaters! Get a real car get a Honda - takes lots of money and work to get power out of those 4 bangers :banana:
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
