alright i thought id add my 2c. i love BOTH, the R32 and the R33. I wish i could own both. I always admire them when i see them on the road. Hell i even get waved at in my 33 by drivers(32,33).
Iv driven both. The R32 seems more punch, due to the lack of torque as compared to the 33. The 33 has more weight however has more torque. Stock for stock tho, the 33 will win.
The 32 i feel gives you more driver feedback. Neither of them are slow. The 32 likes to rev out. the 33 doesnt NEED to rev out as it has more immediate torque. Down low, the R33 will take the cake anytime, anywhere, however the 32 closes the gap at the top of the rev range as it peaks then.
I love the shape of the 32. damm sexy!
  • Replies 165
Posted Images
It doesn't close the gap at the top end... I overlayed a mate of mine's 205rwkw R32 GTSt dyno plot with my 280rwkw dyno plot from the same dyno. The R32 was running equivalent mods to mine (bigger turbo, ECU, injectors etc) but with more boost. His lag was about the same, and if anywhere the gap "closed" in the midrange which is probably mostly to do with the larger amount of boost - my dyno plot actually pulled noticeable distance away from his one above 6000rpm. Despite the hype, in my experience when you go a bigger turbo etc on an RB25 they rev harder than RB20s too, and still don't need to.
But RB25s are for lazy drivers who dont want to work hard for their performance :D Dont get me started on RB30s!
R33 is simply the better car on paper. Problem is cars of this age are all so different with regards to mods and condition. Your friends RB20 may not be as well bolted together as your RB25...soooo many variables. Here is an example of my RB20 vs two RB25s. So it all depends on the particular cars you want to compare as to what your opinion will be
  Roy said:
But RB25s are for lazy drivers who dont want to work hard for their performance :banana: Dont get me started on RB30s!
Haha I'm not sure if you are joking or not, I knew someone who had that honest opinion. If you went from your RB20 to an RB25, do you think you'd suddenly not try and milk everything it has to give? You've done an awesome job of making RB20s look better relative to its RB25/26 cousins than it should do - I credit you and your car setup more than the engine, makes me wonder how you'd go with a decent RB25 or 30 :)
The dyno plot you have used there doesn't really show anything, all I get from it is you have a different tyre speed vs revs to the other two cars and are probably running more boost. Australia, for heavens sake - get some hub dynos!!
If your talking lazy then EVERYONE who drives a Skyline is lazy taking the turbo option... what a bunch of cheaters! Get a real car get a Honda - takes lots of money and work to get power out of those 4 bangers :banana:
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
