Wouldnt go that far but it is very nice. Can see its a lil rough around the rear wheel arch but hey, its a missile, right?
Best part -its a factory bodykit! not an expensive look to achieve, but effective.
https://www.sau.com.au/forums/topic/214630-unicorn-of-pain/#findComment-3791630
wheels are 18x9.5 +3 all around
huge mod list, but im not gonna list it, once it gets tuned, and i have dyno numbers i will let it all out. PLus im still doing work
my Uras Inner tie rods came in today ::D
https://www.sau.com.au/forums/topic/214630-unicorn-of-pain/#findComment-3791975
looks freaken hot!!! (except the eyelids ... not really a fan)
Wish my roof racks had of made the trip ... damn compliancers keeping them!! :D
So how low is the car? like mm from the ground?
I've got a DAYZ kit coming, so if l keep the car l plan l going as low as this pretty much.
Oh ... and any bigger images, l need a new wallpaper!!!
Edited by -FUZZY-
https://www.sau.com.au/forums/topic/214630-unicorn-of-pain/#findComment-3792613
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
    • I wonder if these would be discounted when they have their big sales? because if so would be a great time to actually buy them could even end up cheaper than buying from quickjack in the end.
