I'd recommend PDR-TEK: http://www.pdrtek.com.au/
He's based in SE Melb but he's mobile so he might still be able to come to you. Does a lot of stuff for both the Skylines and WRX club guys...fixed 3 dents I had and I could barely notice a mark afterwards.
John is the guy to be speaking with :)
His pricing depends on the severity of the dent and the type of access he has to the panel (inside of the panel too). It would be best to give him a call to discuss it with him so you have an accurate indication on pricing
John is the guy to be speaking with :wub:
+1 does awesome work. Dont just look at who is cheaper, get the job done from someone you know is going to do it properly.
taken from detailaddiction.com
if Damian recommends him, i think it's safe to say the man does impressive work
"Mr. Dent provides the best paintless on-site Dent Repair service in Melbourne.
I have been servicing many prestige dealerships for 20 years and am more than happy to service your vehicle.
If you would like to contact me, you can by calling 0418 538 117
Thankyou,
Vincent Veltre"
hey guys,
is there any places in northern suburbs melbourne (or surrounding areas) that do paintless dent removal?
cheers,
dave.
Did you end up getting anyone out to fix the dent?
As I need to fix a couple of minor dents up on the GT-R.
  • 2 years later...
I used Jason at Dent Vanish (0402 699 924) and was very happy with his work and prices.
Sorry for bringing up an old topic...
does anyone know a good PDR guy in Melbourne? prefably around SE area. Tried PDRTEK but that bloke never seems to answer his phone.
Thankyou,
Vincent Veltre"
Used him to fix 2 dents on the GTT before i sold it - flawless work, 100% recommend Vince
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
