Item: 6 x 440cc S15 Injectors
Age: As old as an S15
Condition: Great
Price: $350 delivered anywhere in Aus
To Fit: Direct replacement for the R33 gtst and capable of 250rwkw + a bit more with a FPR
Contact: PM if interested
Comments: Selling as they are not large enough for my new master plan, picture only of 1 but I have 6 identical
Item: GTR fuel pump on bracket bolt in with strainer and plug
Age: As old as a GTR not sure which model possibly R33
Condition: Good
Price: $80 delivered anywhere in Aus
To Fit: Direct replacement for the R33 gtst and capable of 250rwkw perfect match with S15 injectors
Comments: Selling due to not enough flow for my new master plan
This is a perfect combination for a high flow turbo setup. Will sell both together for $420 delivered. These are both direct bolt in replacements no mucking around needed. Pick up welcome also Sutherland shire.
Edited by SexyPete
I had mine flow tested at 3 bar just last week and they flowed 500cc and doesn't the skyline run 43psi rail pressure so id say 480 is spot on and of the of 6 injectors 4 were jdm and 2 were adm i.e. they are the same as already said^^
Edited by SevenAngryPenguins
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
