SAU First Official Event - Observation Trial - Sunday 14th September
Duncan
 Share
  • Replies 86
And yes folks - Fatz brought the rego papers for the Corolla !! He he. Better late than never Pete - I never doubted you M8 !
A HGE thanks to Duncan and Kel who organised the vast majority this event - Great one guys. Hopefully the first of many more successful SAU-NSW events.
Good to see everyone wearing the Skylines Australia Shirts too.
Pity about the wind - Pity about the Club meeting - But hey 5hit happens - it was a great day !
Did y'all like Duncan's trick question ? - That must have got a few of you ! (we all know it was deliberate - not)
Can't wait for the show and shine day !
Congrats to Dino, Lisa, Anne and Simon too !
And as always - nice to put a face to some SAU names !
Cheers guys.
Well all, apart from the bloody road closures over at Homebush, the wind, and the tiny mistake in the instructions, it was a great day out today.
For those who had to escape early, here's the table:
Lee 2
John 29 (OK, you guys were more
interested in the drive, right?)
Pete, Tosh and Bella 178
Mark, Nitaya and Pranee 195 (but disqualified for opening
envelope)
Struan, Drinte and Yassin 198
Ash and Alex 211
Mark and Robyn 212
Margaret and Jenelle 224
Carlo and Athlene 233
Lawrence, Genelle and Wayne 236
Julian and Mandy 236
Mel and Neil 237
And the joint(!) winners:
Simon and Anne
Dino and Lisa on 243 points
Unfortunately since there was only 1 perpetual trophy the winners will be sharing for the next 12 months.
The other prizes were:
Most Lost:
Unfortunately this one goes to Mark, Nitaya and Pranee who were still in Homebush bay an hour after leaving
Funniest Answer:
Ash and Alex, who when asked how many license points for " Drive or use vehicle where sound system emits offensive noise" answered "like maria carey or the backstreet boys?"
Honourable mentions for worst effort:
Pete having his dog Bella as next of kin & navigator
No GTRs for entering on the day, obviously they are all in workshops having sump baffles fitted (SBS).
Thanks to:
The rest of the organsing committee: Kel, Brendan and Dan
Dino for trying to deal with CAMs and their rules on competitive events
Mel and Toulia for donating the food for the BBQ, we certainly did not go hungry!
The 2 cars from *far* south coast who came up for the day, and Shell for joining us from Canberra
Unfortunately the SAU meeting did not go ahead as we did not have a committee quorum.
We hope you all enjoyed the day, next time we will remember a windbreak!
 Share
    • Right.  I'll try my best at a concise "bring you up to speed" on stuff that may be missing here - obviously open to questions or further input from others as relevant. Here's a datalog from a responsive turbo setup with electronic boost control being used a bit, to keep it simple I've marked 3 points of interest.  All of these charts are on the same time scale on the X-axis, so you can reference what engine rpm is doing in the top graph, boost and EMAP (exhaust backpressure) in the second graph, and turbo rpm in the bottom graph. A) The turbo gets it's power from exhaust gas, and pumping air takes work.  As a result you can't just spin a turbo with a fixed amount of exhaust energy and expect it to keep spooling - the bigger the turbo (ie, the more air it can push) the more exhaust energy you need to drive it.   The most obvious ways of getting more exhaust energy are by adding displacement, adding boost, or adding rpm - but as you add any of these the turbo also needs to do a bit more work so there is a big balance of these things needed to even get to your target boost and sometimes that's not even possible. What you can see in step "A" is that there isn't enough engine rpm or boost to reach the level we want, so this is where "lag" is.  The dyno run continues and rpm increases, which gives enough energy to increase boost, which helps spool  the turbine speed up even more - so you can see that the rate that the boost (and turbo speed) are starting to ramp up faster than the engine rpm is, so turbo is really starting to wake up as the graph gets closer to point B....   B) At this point we've been able to reach the boost that is actually desired at this point.   To stop the boost from going further than this the wastegate will open and bypass gas past the turbine, meaning it doesn't continue accelerating at the point it was before but instead carry on at a more progressive rate which matches what the engine needs.   The wastegate will have a spring in it which is rated to a specific pressure where it will start bypassing, but electronic boost control (managed by the ECU) can adjust how much pressure the spring sees in order to allow some tunability on how much boost the wastegate actually sees, and therefore how much exhaust it bypasses.   The tune in this case stops boost from ramping up HARD at around 21-22psi just before 4000rpm, then as the rpm continue it allows boost to continue up to around 25psi higher in the rpm.   You can see the turbo speed fairly steadily increases through the rpm to ensure it's keeping up with the increasing airflow demand due to the engine speed being higher and boost being pretty steady.   If the boost dropped off after a point then you may see the turbo speed level off or even drop.   C) You can see that despite the boost pressure staying pretty flat here, the exhaust pressure is steadily increasing and at this stage has overtaken boost pressure.   This isn't unusual, and is largely as a result of the increasing energy needed by the turbo to pump more and more air to suit the needs of the engine as it revs out further.   There are a bunch of variables in regards to how much back pressure there will be on a given turbo etc, but its one of the factors we manage when sizing and tuning a turbo setup.   When exhaust back pressure starts exceeding boost pressure you will eventually start seeing signs that the turbo is running out, the engine gets less keen to make more power and it gets harder to raise boost further. In this case it's a fairly acceptable compromise for the power level (around 630kw on a 3litre engine with full boost by 4000rpm), but you'd not want to push it a lot harder than this.  The maximum speed rated for the compressor wheel on this setup is around 125,000rpm so you can see its starting to get close on that side as well - I feel like this kind of illustrates some of the turbo related things we both decide on how far to push, and are also limited to how far we can push depending on the parts combination. Hope this helps more than it confuses things
    • For that influx of Spammers we had I made no pic posting and no PM's for first ten posts. This is group based and I've manually updated @Beanie to the Members group which will open up the images and PM's.
    • Thx for the reassuring reply. I’ve got above legal clearance  going in for roadworthy Friday… fingers crossed it’s keeping me awake  bloody nanny state
    • I was actually going to try and dig out a datalog with turbine speed and EMAP haha
    • Wait until @Lithium posts a compressor map and tries to explain what's going on. There is a strong possibility that the OP lives in a digital world and is not comfortable with analogue machines. A turbo is just about as analogue as it gets, with plenty of non-linear behaviours added in on top. Most of us who think we know how they work are actually only getting by on 2nd and 3rd order mental models that abstract away from the actual physics and bring it back to the sort of kindergarten level concepts we can hold in our heads. This is important when you need to hold 10 such concepts in your head at the same time. You need to reduce the complexity of the individual concepts to allow them to be simultaneously held and manipulated. Too much complexity in the base models makes it very difficult to make them work with each other mentally.
