  • Replies 108
Not my point dude lol Neither is the HKS supra running a 4.8ltr V8 TT... or the HKS 180sx running a RB26DET... they are built for speed... OBHAVE was built to be the fastest 'GTSt' which to me is a RB25DET powered skyline... i'm not saying your wrong but i am jus saying his is hte fastest street gtst with an RB25 in it.
I checked out a R33 Skyline with the trust td06-20g turbo on it, it had 550cc injec reprogrammed ecu, nismo fuel pump, external gate, trust manifold + cooler and apexi exhaust, was making under 240rwkw... my current car has a gt3540 and is making 300rwkw using a rb25... hopefully will get dyno'd soon and hoping to making around the 350rwkw mark maybe more. The trust turbo started spooling up at 3000rpm was on full boost by 4500 or just abit after. my current turbo spools up earlier and is way more responsive aswell. Instead of spending the money on a trust td06 id rather go for a garret turbo and save $$$. My cars on 1.2 bar the r33 with tdo6 was on 1.3 but running standard internals.
No offence, but you bought the Skyline you are driving around already with the Garrett turbo on it. You had no imput whatsoever into the design of the motor or turbo setup, nor did you have any financial or availability concerns determining what turbo the car was going to run.
There's more than just a flat out money decision when purchasing a turbo.
Edit: How can you compare a dyno'd car with an unproven value? You can't make a valid comparison on the vehicles power...
No offence taken buddy. The reason i bought a car with all the set up on it is because i couldnt afford to build a skyline to the specs my car is at now. Now the price between the car i bought and looked at was only 2k. Not only that the car i bought is in much better condition.
I understand what your saying here "You had no imput whatsoever into the design of the motor or turbo setup, nor did you have any financial or availability concerns determining what turbo the car was going to run" but i did have enough money to choose what car i was going to buy and what i was looking for. Both cars were dyno'd and had dyno sheets and spec sheets. Looking at both of them the car i bought was much better and worth its price then the skyline with the tdo6.
"There's more than just a flat out money decision when purchasing a turbo" thats right. It depends on many things.
But what i stated was my opinion and what i experienced. Im not critisizing the td06 turbo... its each to there own.
Originally posted by Roy
RNS11Z... can you tell me what exhaust housing the TD06-20g was running on that R33? An did i read right... about 230rwkws at 1.3bar
Im not too sure about that. Im not so cluey on turbo a/r sizes. All i know is that it was using the TD06-20G turbo.
And it was either making 224rwk or 234rwkw... Im definately sure it was not over 240rwkw with standard internals and re-programmed ecu
True that, though how much is it for a Trust TD06-20g turbo?
/cough $3500!!!
Ok that was a shameless plug, but there is not much price difference between a brand new td06-20g kit and a T88 kit. Maybe you should be comparing your setup to a motor with a T88 and internals as well?
Edit - Like Leewah's? :D
YBSLO4
You are DEAD WRONG about the Wolf3D V4.##!
Hear are some facts on the new ECU:
-Fuel and Ignition maps are tunable every 125rpm and have 16 load bands.
-Fuel increments are 0.004mS
-Ignition increments are 0.035 Degrees
-Idle speed control-adj. every 2 degrees of engine temp.
-Boost control-adj. every 125rpm
Heaps more features are also included in the package. I would like to see the tunning features of the Power fc, just as a comparison.
I have had the WOLF in my car for about a year, and has been running sweet (once it was re-tunned properly).
    • There's no way they left the factory like that. In R chassis there is nothing stopping the steering wheel being put on one spline out from straight, and then adjusting the steering arms to "correct" it (sort of). As well as the indicator cancelling there would also be an issue with how tight you can turn in one direction to the other. The other (less likely) possibility is that the "clock spring" (the circular electronic part that allows the wheel to turn while still having an electrical connection for horn and any other buttons like cruise) might not be in place correctly. I don't have any pics of the R33 (or Stagea) setup but there would be a circular locating tab which sits in the steering column to have it straight...if that is not seated properly then the indicators may not cancel at the right point (and, you might also get a HICAS error since it would think you are driving in circles)
    • It will mostly be bad scoring on the bores, which you can almost certainly fix by machining for oversize pistons. I have to say, I am super surprised that any standard turbos made it 35 years down the track before exploding!
    • Thanks for the info mate was thinking 255/35 rears and 235/40 fronts
    • What's the difference? I would have said that between the front and rear axle lines, there's no noticeable diff between a GTR and an NA 2-door.
    • It will be salvageable. It really doesn't matter what is damaged. Opening up a 30+ year old motor for a rebuild immediately means a complete rebuild of the head anyway. Damaged valves just means an opportunity to put in some nice new ones. And in the modern day, why would you not throw at least a nice set of pistons at something. And if you're doing that, why not rods, and ARP fasteners, and so on.
