Awww...that's the whole point of an external wastegate isn't it? What's the use if it's not going to dump straight out to atmosphere? :) I used to do that. Great sound when it opens at full boost!!! To me, an external wastegate is like a BOV. Although they do have functionality (reduces lag/better boost control), everyone knows that the real reason is for the sound. Be that a whoosh or a bark. A whoosh and a bark is even better :)
Let me know how the car sounds when the turbo is spooling. My previous turbo made a much louder noise than my standard one at present. It was a kinda high pitched noise that got louder.
You should get no probs from the cops unless you zoom past them at full boost, cos that's the only time you will ever hear the wastegate. Just be careful, that's all.
Hope the results are good!!!
  • Replies 108
Hmm...it just occured to me, looking at your picture of your turbo and wastegate...does that mean that you have cut a hole into the exhaust housing of the turbo? I believe that a wastegate has two outlets. One usually bolts onto the manifold, where the exhaust gases enter the wastegate...and then the other outlet is for the wastegate piping to flow out to excesss exhaust. Am I right in assuming that you have cut a hole in the exhaust housing? If so, how was this done?
I can see what you're saying, but no matter how well you do it it will never be as smooth as it was originally. And seeing that exhaust gases are going to flow through this real fast, it will cause some form of turbulance problems. Would even cause more back pressure than normal and wouldn't that disturpt the flow of the exhaust gas and affect the spinning of the turbine wheel and the whole turbo as a result?
amu: I think the 20G could produce more than 250kW@wheels. Probably more closer to 300kW@wheels? You said boost kicks in at 4500rpm and this is not laggy??? Or did you mean full boost (1bar) at 4500rpm?
that is full boost.... no way you can achieve 300kw on a 20g ....the 25g yes if all other things are done with it as well... between gear shifts you a still on full boost...that is the most important aspect dont you think.... everyday driving is below that... so there is an advantage there in itself
By fitting the external wastegate off the dump you can have vastly varying pressures on the wastegate and it makes the boost control more difficult. The setups I've seen done with the wastegate on the exhaust housing have all worked well, much to my sursprise aswell.
Oops! Sorry, I forgot that there was a larger one - the 25g. I think 1bar at 4500rpm is still a little laggy for street use...but then I guess it's all to personal preference. I used to have a GT3037S on my 2L and that wouldn't make any boost until 3500rpm. So 1bar probably around 4500rpm...and I thought that was a little too laggy for street.
amu: In terms of driveability, I am strictly talking about *when* the turbo starts making boost...not really considering whether or not the car is on/off boost between gear changes. And to me, my personal opinion is that a car making 1bar at 4500rpm is a little laggy for street. Just my opinion, but other people may think that's fine for the street.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
