the r33 kit will fit a r32, but you just have to use a longer silicon hose (around 25cm) on the cross over pipe that feeds into the plenum...
don't have any pics handy, but have fitted a r33 kit onto a r32 before with no problems, but you need the extra silicone
still up for grabs 220 bloody bargan!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
i need this gawn :P
willing to ship to Canada? (L6Y 3E2)
let me know, also post some pics!!!
