G'day Everyone.
Just doing a shed cleanout and selling a full set of TEIN Dress up Master springs for a RS4. Not sure if this will fit S2, so do your homework!
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...em=180232877379
Cheers,
Michael
:wub:
https://www.sau.com.au/forums/topic/214693-stagea-s1-rs4-tein-springs/
how much do u want?
and how soft are the "s-tech SOFT"?
just whatever they go for on ebay. If there is only 1 bid then $50. I was just going to post them on here, but I couldnt get the images working... Not sure of exact spring rates, see if you can look it up online. They were firmer than stock though. But not bone jarring like a lot of jap springs.
Michael
Michael
Ok! found some info:
STAGEA
WGNC34
1996.10-2001.10 RS-Four AWD
2500 SOFT SKN78-S1B00
\24,000 (MSRP)
\25,200 (incl TAX)
FRONT 3.1k spring rate -51mm ride height
REAR 3.8k spring rate -25 ride height
hope this helps!
from: http://www.tein.co.jp/search/search1.cgi?a...SSAN〈=e
Do you think " 1996.10-2001.10 RS-Four AWD" means will they fit 96 to 2001 model??..so will fit S2??
We will forgive them for saying AWD when it should be 4WD....
Also 51mm drop in the front and 25mm drop on the rear...bit of a big difference bewteen f/R..did you have them on ?
Edited by bluesky4me
Whoops ..sorry didnt read all the add..is the car in the pic fitted witht the springs in question?...a bit hard to see the amount of lowering cos of the darknes around the wheels...
G'day,
According to the tein website they will fit an S2 without any problems. But as I've only had them on a S1, I can't be sure 100% and it's worthwhile doing some homework on them before buying. They are fitted to my S1 in the picture when I purchased it. There is a difference between front and back, but a stock stag does sit a little nose up, and with them on it sat very well. Sorry, it's the only pics I have with them fitted.
Cheers,
Michael
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
