hey guys, I posted some information about my RB20DET with twin stock RB20 turbos, but ive been hearing from alot on people that is is going to be extremely laggy. So ive decided to make to the turbos in sequential.
We are going to put a valve in the exhaust manifold so that when one of the turbos is spooled up, the valve will open and allow the other turbo to spool up.
i believe that another 1 way valve will be needed where the compressed air is , so that it wont travel into the other turbo while one is only spooled up.
if anyone has any comments of knows how this works or if this will even work or ANYTHING please post
thanks
https://www.sau.com.au/forums/topic/21472-sequential-turbos-rb20dett/
If you have two 3-1 manifolds so three cylinders are feeding 1 turbo each it wont work. You will be wasting half your exhaust gas.
To get the boost response you want you would need to have a 6-2 manifold that has a shut off valve to one turbo to allow the other to spool up normally, probably slower than normal because of the messy manifold.
You would then have a massive flat spot when you open the valve because you halve the gas flow to the turbo thats making the boost and have to wait for the other to spool up. Plus there is a hell of a lot of plumbing, have a look at a factory sequencial car, plus the fact that sequencial cars have 1 small and 1 large turbo.
You will be better off with two smaller turbos on two 3-1 manifolds. get a pair of GTR turbos if possible, or a pair of T25s and modify the manifolds to a T2 flange. You will not get a good response from the 2 RB20 turbos, 5000rpm plus.
Sorry mate
I think the RB20/25 turbo share the exhaust housing and turbine wheel and it is one of the smallest on the mid frame turbos.
When you get smaller, as in T25/28, the turbo has a smaller core. I don't know whether one of the housings off these turbos will fit.
You'd still need to change the flanges on the manifolds though
Originally posted by Squizz
The same could be asked of an Aussie 31 driver spending way too much on brakes and suspension...
.... but that is such an easy concept to understand... brake and suspension upgrades so he can go faster...
... two turbos that are oversized, attempting to make a never seen (at least by me) setup on a RB20DET, hard enough to get the twins running without messing around with sequential setups... im sure someone more technical minded could expand, but I can't really see it being a viable exercise...
The simple (and cheaper) option would be as suggested smaller twins or a bigger single!
Shut up squizz.
He needs to ask himself why.
He is talking about crazy plumbing valve setups for two turbos, and he doesnt even know how sequential turbos work.
Squizz - my brakes and suspension were suitable, realistic, and researched. They were done, and work extremely well. Very different to this crazy idea.
    • Hey, yeah I really like the color. Only paint I'd rather have is KN6, but those are expensive. Right now I'm trying to get the car to the point where I can get it tuned to 370hp so the whole setup can be driven legally, and pass the next inspection that is already due anyway. Beyond that lots of rust fixing I'm afraid, winter project is most likely going to be a front end teardown and fixing the strut tower rust. I know these can be driven daily but I don't think I will do so anytime soon. Will post a build thread soon with a list of issues and futute plans.   Cheers
    • Wanted to reply to this topic. I'm in the somewhat same boat with our Stagea. I'm trying to install a different rear diff. The Stagea/Skyline uses mounts on top of the rear diff for the ATTESA pump. Any way you can relocate the pump? I did find this kit https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • So here's the deal, my wife picked up an S2 AWD Stagea. Super cool, clean car. Looks like the owner in Japan went track spec as it's got some heavy modifications including Exedy twin disk, tension rods, coilovers, GTR brakes, oil cooler & a Nismo 2 way rear diff. Now, cool mods for sure. But, she is just using this as a casual daily driver. The 2 way rear is AGGRESSIVE. It also has solid subframe bushings & poly diff bushings. So that doesn't help either. So far I've tried changing the diff fluid to the correct fluid. Even tried a little friction modifier. No help. This thing clunks, skips the tires & has some slight whine/NVH when driving. Might sound like I'm being picky, but just trying to find a better solution. Here in the states, it's impossible to find a Stagea rear diff. No luck. I do have a 300zx non-turbo diff. Same ratio, 5 bolt axles. On the Stagea, you need both front & rear diff ratios to match. This car is a 4.083. I'd like to just swap a normal rear diff into this thing. Nothing fancy. Even open diff is fine. She's not tracking the car LOL The difference is that the ATTESA pump mounts to the top of the rear diff. There are 3 total mounting points for the pump on top of the diff. With all this being said, what would be the best way to go about this? I could remove the Stagea diff & see if I could get somebody to possibly weld the 3 tabs/mounting points onto the 300zx diff so we could mount the pump on the 300zx diff. I could swap the internals from the 300zx into the Stagea diff but this is not in my comfort zone. Is it possible to mount the ATTESA pump to the underside of the car? Sorry for the paragraph. Just trying to figure out how to go about this. Any help is much appreciated! Stagea Differential - Note two top tabs, one bolt hole for ATTESA pump mounting   300zx Diff - No mounting tabs Also found this mounting kit ?? https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • Not ready yet, but maybe later in the year?
