Make:Nissan
Model:BNR32
Milage:85,000k
Transmission:Manual
Colour:Gun Metal
Complied?yup
RWC supplied?Can arrange one
Currently registered?Yes
Price:$29,000 fairly firm
Contact:[email protected]
Comments / Modifications:
Car is well looked after, had it for nearly 3 years now, no problems whatsoever, alot of money gone into keeping it reliable, driven very sensibly, minor surface rust in boot well, small speck on roof, no crash history, want to get rid of it, back at uni, its costing a bit, thinking of something non-turbo, small and cheap :D, not really considering any trades but show me what u got. heres what i've done to it
* upgraded turbos, it has Garrent GT2860R/7 x 2 (310hp ea.)
* Power FC + hand controller
* 600cc nismo injectors
* splitfire coils
* Z32 afm
* bosch intank pump, 500hp
* CES dump pipes
* rear bushes been fixed
* front have been replaced
* 17x9.5 drifteks (bronze) new rubber on front, rear has about 80% had alignment done too
* exhaust and muff
* tein coilovers
* nismo strut brace
* rotors have been replaced
* new GTR badge :)
* JL splits, JVC ipod headunit, 12" JL sub, beefy cadence amp
* ORC twin plate clutch, good for 700hp, dampered
* produces 280kw rwkw safely, good for 300 with bigger fmic.
feel free to email me if you have any questions
regards,
Dan
Images: comming
https://www.sau.com.au/forums/topic/214730-1990-r32-gtr/
  • 3 weeks later...
Free bump, clean car..
Just curious what sort of boost were you running to make 280kw? How is low down pick up? Stock head gasket? Did this limit you at all?
Sorry for the brain picking.
Cheers Tomek
Edited by Tomek
https://www.sau.com.au/forums/topic/214730-1990-r32-gtr/#findComment-3873508
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
