Ahg Skidpan... Anyone Know When The Nextis?
  • Replies 50
I could try to organise a training event in June (pending the other commitee members approving).
I can orgainse the day etc, but unfortunately we get the weather that we get.
Interested?
/hey all, just wondering if anyonehasheardof another ahg skidpan day happening? i'm back from work on the 25 april untill the 4 of may.
cheers Asho
Well my B'day is on the 6th, lets do one the weekend prior!!!
W00T!
Brad, I'm definately up for a skid pan. I would love one in the wet. Last one where I was just spectating, everyone got to race around in the wet and I really wanted to join the fun. June sounds perfect ;)
Brad, I'm definately up for a skid pan. I would love one in the wet. Last one where I was just spectating, everyone got to race around in the wet and I really wanted to join the fun. June sounds perfect :D
True ey, you were busting to go out and fang the 33 in the wet.... :D
I really like the fact it was near torrential... Then it spat for a bit, then we got drying conditions...
Too bad it started to gte really hot near the end though... Rain + Heat = humidity ftl! :D
Ryan, come and do a few round of the MC Autotest. Its good fun!
I'm saving that for next year. This year I want to get my driving skill up and then next year try and be at all the Autotest events. By the end of this year I'm hoping to have my suspension and wheels/tyres up to scratch. Just put an enquiry for some new rims yesterday. Then I have to save for tyres and then suspension :cheers:
oi, I was looking at entering either the last round or two just as a bit of a 'wildcard' entry... You up for giving it a go??
I'm looking at entering next season as well, again, once suspension/tyres, cooling and tuning is right up to scratch.... As u said..
That sounds pretty tempting Mark. I need to give my car a service first. I can hear the timing is slightly out and I don't want to hammer the engine like that. When are the last two?? Can't be bothered checking the site :cheers:
That sounds pretty tempting Mark. I need to give my car a service first. I can hear the timing is slightly out and I don't want to hammer the engine like that. When are the last two?? Can't be bothered checking the site :)
September 2008
Sunday 7th.........................................................................AHG AutoTest Round 6(AM Session)
October 2008
Sunday 12th.........................................................................AHG AutoTest Round 7(AM Session)
http://www.skylinesaustralia.com/forums/20...ar-t183177.html
Here it is...
Nub... :O
haha, thanks :P
I knew it was there, but I was at work, so I couldn't be bothered looking lol
That looks good. It gives me plenty of time to get the car serviced. Maybe even have my new rims on by then :) Will have lots of grip with those 265's at the back :)
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
