As far as i heard and seen these kits are fine for the people with series 1 bumpers... Series 2 may require a bit of fiddling.
Anyway ive ordered one for my series 1.5.. lucky i got the series 1 front bumper so it should install with ease.
Ill let you guys know how it goes.
If you have the m type front bar, as i did. You will be require to "fiddle" to get it perfect. but thats just me being me:)
What i did is drill a new whole in the center bracket (on the core) so i could center the cooler more to the passanger side.
By doing that, it not only centered the "core", but it also allowed for the bracket on the pipe thats bolts to the chassis (on the passanger side) to meet up with the intended whole to bolt it up too.
So keep in mind, you may still need to modify the bracket if you want it to be dead center and 100%
If you dont, it results in a off center cooler like the above post :yes:
If you get stuck or have any questions just PM me, im happy to help.
  • Replies 43
Posted Images
They seem to sit a little to far to the left
I have done my BLITZ return flow cooler in black and am looking at going back to a polished cooler so consdidering selling the blitz and buying another return flow setup
Has anyone got any results with this cooler say on a dyno with bigger turbo etc
I am looking at running 18 - 20psi + through one and want to know if it will hold up
  • 5 years later...
to bring a dead thread back... anyone know if it's as fiddly to fit a cooling pro fmic onto a r34?
Seems like a big hassle to chuck it onto a 33, and if it's the same for the 34 then i won't bother.
buy a jap kit, don't get the JJR kits.. fuark me.. what a pain in the arse to fit on Ph@t G's car
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
