So the short of it is, a mate has a set of r33 s2 struts floating around.
Will they fit my s1 Stagea?
In related matters, my current struts creak rather alarmingly on braking, I'm quite sure it isn't a sign of serious trouble, but the noise is discomforting nonetheless.
So is there a way to stop this?
https://www.sau.com.au/forums/topic/214799-quick-question/
  • Replies 89
funny
mine doesnt
Series one
RS4
Dayz
same thing he has
I have R33 suspension (coilovers) on it
ZERO problems
i mean, i can go take pictures if youd like.
REALLY funy part
GTR and GTST fronts...are the same, just different valving and springs....
the rears are the different ones.....
again
yes it will work
https://www.sau.com.au/forums/topic/214799-quick-question/#findComment-3793389
so they've different connectors on the front and back?
so I'll be half right? :P
Before we go further
Yokotas, are your struts GTR or GTST struts?
If the fronts are the same on gtr/gtst thena full set of gtst struts will fit on the Stagea?
Edited by Oddy man
https://www.sau.com.au/forums/topic/214799-quick-question/#findComment-3793390
yes
R33 GTST will fit on yoru stagea
https://www.sau.com.au/forums/topic/214799-quick-question/#findComment-3793407
i love this thread.
gtr/gtst fronts are the same bar the valving.
rears are diff.
get gtst and tune the damper, or get the justjap coilovers for stagea, or tein ones :thumbsup:
dont mix and match as it can cause pitching thru corners, ghey.
https://www.sau.com.au/forums/topic/214799-quick-question/#findComment-3793993
So I've just crawled under the car, risking caltrop weed to the back and groped my way around
all the struts are the same, and seem to be r33 gtst style
Since the ones coming my way are better than what I have (and a bit lower), I'll be doing the swap.
Seeing as the only price I'm paying for them is a Sunday afternoon and a carton of Corona, when they arrive I'll be taking pics, and posting my report for the betterment of Stagearizers everywhere.
That's a few weeks ahead though, but stay tuned nonetheless - I guess it'll be left til then to determine the success/failure of the job.
EDIT: I don't suppose any of this controversy could have stemmed from engine type? My Stag is the rb25, anyone feeling like groping a Neo and reporting details?
Edited by Oddy man
https://www.sau.com.au/forums/topic/214799-quick-question/#findComment-3794462
they should fit but will they work acceptably?
the stagea weighs a fair bit more than a GTS-t roughly 1350kg to 1750kg (give or take). personally i wouldn't do it but then again i have never driven one with GTS-t shocks in so i am just guessing based on what the nissan engineers would have deemed reasonable based on spring rates and weight.
could it affect braking distances if things turn to shit? (interested to hear if someone has more to say on this front).
ultimately your call.
ps. the RS4S (manual) has a fork type on the rear like the R33 GTR just in case anyone reading owns one.
Edited by wolverine
https://www.sau.com.au/forums/topic/214799-quick-question/#findComment-3794541
you know what
i bet you 1,000.00
that if you picked 5 random people, that dont do track time
and put them in my car
and put htem in a random car with overly expensive shocks with little collars that you move for height
you wont be able to tell the difference
only diff is mine is stiffer, and handles super duper flat around turns
its al relative, most of you guys talk out of your ass, and on hypotheticals, while im sitting here DOING the stuff you say cant, or shouldnt be done. I dont have problems making apexes, i dont have problems in touge keeping up with other skylines and silvias. When you buy aftermarket suspensions, its stiffer than stock correct? stiffer than the gtr front suspension? YES I build my cars to handle, comfort is ALWAYS a sidenote to that. You cant have a fantastic handling car and be plush...its not possbile
so yeah, if you were putting stock for stock on the car MAYBE it would be an issue, but aftermarket coilovers (i would never buy anything otherwise) its not going to make a lick of difference to the average driver. And if it does, throw the fronts out to get revalved for 200 bucks and call it a day
quit reading your life away, and start doing.
https://www.sau.com.au/forums/topic/214799-quick-question/#findComment-3794622
as far as i can tell, this is what he is talking about doing.
you have a strange habit of calling everyone that disagrees with you idiots, stupid or otherwise.
next time someone throws a thread out there maybe it would all save us time if they direct it at you.
https://www.sau.com.au/forums/topic/214799-quick-question/#findComment-3795306
but you guys said it wouldnt work
NOT that its undervalved (which i stated) or that they arent for a heavier car
you said it woudlnt work
So yes, i call you that disagree idiots.
I am here, telling you for a fact, not hearsay that it works. You want to know why? I HAVE THEM ON MY CAR. I have r33 shocks on my car. so who are you to tell me it doesnt work, when it obviously does.
Its like the deaf leading the blind.
Im sure if sydneykid came in here and said they fit you would all bow down and kiss his feet.
https://www.sau.com.au/forums/topic/214799-quick-question/#findComment-3795330
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
