i have read and re-read my post and i never said they wouldn't fit but they would probably be undervalved (due to the weight difference). so the question of whether they would work acceptably is up for grabs.
aftermarket R33 shocks is a different ball game for valving hence you have obviously found something you are happy with.
getting back to what was posted, do you think standard shocks will work acceptably?
  • Replies 89
standard is unaccaptable to me
every car i get, within a week they are in the trash
so IMO, no, even on a stagea, standard shocks do not work acceptably
but you act like the remark was directed at you...it was directed to everyone who said they woudlnt work
they will work, maybe not parfet (if standard) but most wont be able to tell. I mean, most people dont know when a shock is blown
its al relative, most of you guys talk out of your ass, and on hypotheticals, while im sitting here DOING the stuff you say cant, or shouldnt be done. I dont have problems making apexes, i dont have problems in touge keeping up with other skylines and silvias. When you buy aftermarket suspensions, its stiffer than stock correct? stiffer than the gtr front suspension? YES I build my cars to handle, comfort is ALWAYS a sidenote to that. You cant have a fantastic handling car and be plush...its not possbile
so yeah, if you were putting stock for stock on the car MAYBE it would be an issue, but aftermarket coilovers (i would never buy anything otherwise) its not going to make a lick of difference to the average driver. And if it does, throw the fronts out to get revalved for 200 bucks and call it a day
quit reading your life away, and start doing.
:D 100%
I love proving people wrong, who say it can't be done!
If I listened to everyone, I would never have done half the things in my life that I've done. Nor built half the insane projects I have.
i'm glad we agree on the standard shocks not being suitable.
remind me not to stand near anyone when you are holding a shotgun. :)
but you guys said it wouldnt work
NOT that its undervalved (which i stated) or that they arent for a heavier car
you said it woudlnt work
So yes, i call you that disagree idiots.
I am here, telling you for a fact, not hearsay that it works. You want to know why? I HAVE THEM ON MY CAR. I have r33 shocks on my car. so who are you to tell me it doesnt work, when it obviously does.
Its like the deaf leading the blind.
Tell me then how you fit R33 rear strut tops with 115 mm bolt centres into a Stagea that has 80 mm bolt centres?
Im sure if sydneykid came in here and said they fit you would all bow down and kiss his feet.
That's because I am usually (but not always) right, it's called runs on the board.
Cheers
Gary
Cheers
Gary
obviously youd transfer your stock tophats to whatever you put them on.
i have stock tophats on my coilovers, no need for anything else.
the argument is if they woudl fit
so yes, they fit
Now, if his car was on blocks with no suspension, that would be different.
you know what
i bet you 1,000.00
that if you picked 5 random people, that dont do track time
and put them in my car
and put htem in a random car with overly expensive shocks with little collars that you move for height
you wont be able to tell the difference
Pick 5 Stagea people and I think you would be proven wrong. That's your problem, the average Stagea owner is more educated on what is good and what is bad than the average punter. Talk to your audience, on the Stagea thread don't treat the readers like idiots.
only diff is mine is stiffer, and handles super duper flat around turns
So it's slow then and lacks traction.
All that proves is they are doing worse than you, not that you are doing it right.
Wow, you better tell BMW and AMG and Porsche and Jaguar etc that they are doing the impossible.
So tell me, when you buy your V35 or M35 how are you going to use "coil overs" in the rear?
Because the people who really know are aware that "coil overs" is simply a description of the layout of the springs and shocks. That Skyline R32/33/34's and Stagea 34's come with coil overs standard.
Much fun for all
Cheers
Gary
so yes, they fit
So you admit that they don't fit.
But wait there's more............
What do you suggest they do when the standard Stagea rear spring seat is 75 mm and the coil spring in the coil over kit is 60 mm, or 62 mm or 65 mm or 70 mm? They are all common coil over sizes. They have to change the springs? Oh look, another reason why they don't fit.
Cheers
Gary
I have R33's in the rear of my S1 4wd Turbo.
iijj has driven it he and I seem to think it is fine.
ant
R33 what?
R33 rear shocks only? Yes they will fit and they will work OK for a while, as long as they are in good condition.
R33 Springs? Nope they won't fit, wrong dimensions
R33 Strut tops? They won't fit either, wrong stud pattern.
What we are talkibng about here is complete R33 shock/spring units and they definitely won't bolt straight in, for the reasons above.
Cheers
Gary
R33 what?
Cheers
Gary
Must be just the shocks only then.
Was that way when I got it... I noticed it a few weeks ago when I had them out... written on them in white marker.
Ok so I need to keep an eye on them as they wear... good to know.
ant
Cheers
Gary
incorrect
tophat has rubber cup base, if you insert it, and drive, the heat generated from the spring will seat it in its new position on the tophat
problem solved, i had the same problem
anything else?
R33 what?
Gary is right.
I just fitted Ohlins coilovers designed for an R33 setup into my S2 Stagea at all 4 corners. I had the rear hats removed and modified by an engineer to change the bolt pattern from 115mm to 80mm, and machine down the hat itself down to 115mm diameter maximum along the mounting bolts length (its actually machined oval shape).
Stag now feels mucho better!
:shrug:
some people worry about every little detail
some people spend half that time just doing it and makign stuff work and get to the track faster :P
im that guy
im using parts from 5 or 6 different cars on my car to make stuff work
I mean, it doesnt hurt that i have like a junkyard of parts at my house from my past track cars, but its not hard stuff that im doing.
Well FWIW, when the shocks get worn out in my RS4V (which probably isn't far away...), I'll simply fit a set of Nismo S-Tune's to suit. From memory the price quoted was ~$1500 for a complete set (inc springs).
They WILL fit, and should work a treat on the road.
:P
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
