Grant, seriously, stop treating us like clowns just because you disagree with what we say or how we choose to do things here IN AUSTRALIA... It's getting tired.
Here's a few things to think about:
  • most of us use our cars as daily-drivers in Aussie conditions - we regularly encounter a huge variety of road surfaces; traffic and weather conditions; freeways, suburban streets with speed hump, roundabouts; broken and/or unsealed roads, etc.
  • most of us RARELY, if EVER take our cars to the track. When we do take them to the track, not everyone wants to drift their wagons - some like grip driving.
  • most of us would like a COMPROMISE between comfort and handling, due to the factors stated above.
  • most of us would prefer to SHARE our knowledge and experiences, and learn from others, rather than have it DICTATED as to what is "right" or "wrong: with no consideration as to how and where their car is used.
  • most of us would like a simple, one-time solution to get what we need. We may not have the time, money parts available or opportunity to test all of the different set-ups and combinations available around us.
Fair enough, you do a fair bit of testing and have found things that you seem to prefer over what's been suggested here, but just because they suit you it doesn't mean that it will apply to everyone else. You seem to do a lot of chopping and changing of parts, which might well be the way to get to the set-up you prefer for the way you drive your car, but (correct me of I'm wrong here, please, SK) Sydneykid has done extensive testing over a period of time to make sure that the set-up he has worked out will suit for an extended period of time over various conditions.
  • Replies 89
some people worry about every little detail
That's why the cars I engineer win events, I worry about every little detail. That's why there are over 160 guys out there with Group Buy kits in their Skylines and Stageas, because I cared about every little detail when I was engineering them.
some people spend half that time just doing it and makign stuff work and get to the track faster
But when they get there they go slower.
im that guy
Seems like it
im using parts from 5 or 6 different cars on my car to make stuff work
This topic is about making bits from 1 car (R33GTST) fit into another car (Stagea), that's 2 cars not 5 or 6.
I mean, it doesnt hurt that i have like a junkyard of parts at my house from my past track cars, but its not hard stuff that im doing.
Not everyone has that luxury.
tophat has rubber cup base, if you insert it, and drive, the heat generated from the spring will seat it in its new position on the tophat
problem solved, i had the same problem
The OD of the metal top hat spring seat is 75 mm, the rubber sits around it. If you use a spring of lesser ID (60/62/64/70 mm) then it will contact the top hat as the rubber compresses.
Tip.....if you want a consistent spring rate for predictable handling and don't care about NVH, then you should remove the rubber spring seat. It has a spring rate all of its own that affects the main spring rate on initial compression and final rebound. Which are precisely the times you want maximum shock absorber control of the spring, having 2 quite different spring rates (the spring itself and the rubber seat) makes life unnecessarily difficult for the shock absorber.
Cheers
Gary
...and some people know and understand suspension and wheel theory and how it applies to the real world conditions. While some think that doing this is a good idea.
Funnily enough, the same person who argued with me about 6 months ago that increasing camber doesn't increase tyre wear, and then makes this statement recently
pu tit this way
my cedric wore through SIDEWALLS
not tires.
literally
a set every two or 3 months
Or, you could listen to the guy that helped bilstein develop a suspension set up specifically for the stagea, and also has a proven TRACK record in stagea's and skylines.....
*leaves*
Cheers
Gary
shit, i didnt even think of taht
good lookin, im gonna do that tomorrow
lol you do realize, that the entire suspension was basically reengineered to be exactly liek that?
increasing a moderate amount (think 2 or 3 *) wont really increase tire wear
the -15 to -20* that i have on my cedric, is a little different.
dunno why you capitalized track
this is like the 4th track car ive built, your point?
No....surely not. Why would anyone in their right mind "engineer" something that is so obviously wrong?
If they were truly "engineering" it, then it would be right.
It looks to me more like a dump it on its ass exercise and who cares about the consequences.
Properly re-engineered, you could dump it on its ass and have the correct geometry.
75 mm is more than the standard bump travel (zero bump stop contact) on a Stagea.
75 mm places the rear lower control arms at an angle which results in 4 degrees of dynamic camber change with full suspension movement
75 mm results in a minimum of 2.75 degrees of rear static negative camber
75 mm causes 3 mm of bump steer on the rear at a modest 50 mm of compression
75 mm places the front lower control arms at an angle which results in zero increase in NEGATIVE camber on compression
75 mm results in a minimum of 1.25 degrees of front static negative camber
75 mm causes 1.5 mm of bump steer on the front at a modest 40 mm compression
And you don't think that screwing up the geometry like that going to increase tyre wear? :(:D:)
Not different, just worse.
Cheers
Gary
75 mm results in a minimum of 1.25 degrees of rear static negative camber
*grabs the nurofen and a beer*
Gary
becuase its a style
VIP is a style that is nothing but show.
Its who can fit the biggest wheels, with the best fitment
and i achieved it
regardless if you understand why, or not, its the style
you dont have to like it :P
im done though
i bow down sydneykid
well, let me rephrase
i dont care
ill keep doing my thing, you keep doing yours
becuase its a style
and i achieved it
you dont have to like it :laugh:
im done though
i dont care
It's not a matter of liking it or not. The fact is there is no real engineering in it, I could achieve the same look in an hour with 4 bits of 4 x 2 instead of springs and shocks. It would probably handle about as well. Real engineering would be achieving the "style" and making the car driveable at the same time. Anything less than that is a cop out and the word "engineering" should never appear in the same sentence as VIP.
That's the real problem I have with the "style" it's a lie, a fake, a shame, phony, it's deceitful because it gives false belief to people who think you can have that "style" cheaply and a real car at the same time. Real credibilty would belong to someone who can engineer in the "style" together with true daily driveability. Citroen did it 50 years ago, copy their engineering solutions and you would revolutionise the VIP world.
Cheers
Gary
Cheers
Gary
how about this then
You make that same fitment
a 10inch wide, -30 offset wheel, on the back of a Y33, with just a 20mm pull.
go for it
VIP is not a style for cheap people
its not a style for people that think that way. The good thing about it? It weeds out people that cant hang.
Id be keeping my cedric if the military wasnt bitching about me having 3 cars (i can only own two)
Mercedes did it like 5 years ago as well didnt they with the little open wheel car thing
All im saying, its not just a bolt on affair, you have to have a fully adjustable rear suspension setup, which is already costly for most people. Then you have to cut and modify those arms to achieve that effect.
Is it reasonable?
no
Is it safe at that camber?
Not really, if you dont keep up with your tires
Regardless it is a style, which is next to drifting in japan, and quickly becoming the largest up and comming "fad" in the US.
i kind of like the fact it takes alot of money and dedication to do hte more extreme stuff in VIP, it weeds out the poseres
regardless
Lets stop the bickering, i dont mind you, your a smart guy. Im 22, i am hard headed. Just the way it is
Not wanting to waste money on destroying tyres with ridiculous geometry doesn't make us cheap!
I think you need to get a grip on reality ... and engineering in general.
We're trying to discuss what is street-able as an overall modified package. Not what requires you to clench your teeth and hold your fillings in, and open your wallet after every trip home.
:laugh:
the ride wasnt bad
it wasnt bone jarring
it was abotu as stiff as my stagea is now
and remember, I didnt bring up the cedric, someone else did......
i didnt mention it anywhere until he did.
but you guys arent attempting VIP, so stop thinking everythign i say is an attack....it wasnt even remotely applicable to any of you.
you guys really CANT do it becasue of the laws, not your fault.
how about this then
go for it
Is it reasonable?
no
regardless
I am not bickering, well trying my best not to anyway. What I am trying to do is challenge your thinking. Let's try this;
You make that same fitment, a 10inch wide, -30 offset wheel, on the back of a Y33, with just a 20mm pull.
I have no idea what the underneath of a Y33 looks like but based on other Nissans....How about a 10 inch wide, -35 offset wheel, with a 15 mm (outer guard) pull, a 5 mm (inner guard) push and 5 mm (top of wheel) camber correction. It uses pretty much the same components, just with a bit more engineering thought put into the suspension geometry. The "wheel flush with guard look" would be the same but it wouldn't have the stupid looking camber angles and it might actually drive.
Cheers
Gary
cant do it
in order NOT to hit the wheel on teh fender, i had to max out the camber arm with no lock nuts, spot welded to prevent moving
i can however fit a 19x10-7offset with minimal camber on teh same pull i have now.
i had to shorten the traction rod to pull the wheel forward from all the camber i added.
cant do it
I think you missed what I said, re read it and you will find that the top of the wheel ends up in the same place. So the wheel won't hit on the fender any more than it does now.
Cheers
Gary
    • Hey   ive gone for a terminated harness on my build so selling brand new unused and unopened piggy back harness  https://www.haltech.com/product/ht-141357-elite-2000-2500-nissan-skyline-r32-33-r34-gt-r/ Located Bathurst NSW   price $600 + postage
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
    • Yuh, My new R34 box is sitting on the workshop floor (in its large shipping box, which is a nice thing on its own), along with a front plate to convert to push clutch. There was no way I was interested in rebuilding my existing one. Was only partly interested in the risk of buying a used one. But, if you want a 2nd hander, I can point you to one in/near Melbourne at least. @Komdotkom has one that should be in good enough condition to be usable. I don't think it's in a for sale thread, you'd have to message him. @redzedhas one that definitely needs a rebuild.
