The first event at the new track is supposed to be on 06 July, it is looking pretty awe inspiring. From memory the bitumen is 6.5M wide.
I have had a walk around it during construction and I can tell you it is going to be a lot more scary to drive than the old track, as well as around three times as long. There are a number of blind, cresting, off camber corners and spots where the track is going to just disappear from in front of you. Think of going over Skyline at Bathurst.
Just to add to my last post. I found some video footage this morning of the last working bee day at the new hillclimb. People that showed up to help were allowed to drive around it gently to have a look, it will be a challenge to go fast on. I think mid range grunt and quick spooling on turbo cars along with good traction and a complete lack of understeer will be the keys to a fast run. And there are a few corners that should be able to be strung together for those that are into drift (Assuming they are going to run drift events there)
Funnily enough I missed the link you posted when I was reading through the thread Bec. Hopefully it stays up this time. I am really looking forward to having a run there but I reckon that it will be quite a few runs before I would be looking for the limit. A couple of spots look pretty unforgiving of mistakes (The Eau Rouge moment at the very bottom of the track for one)
I think anything with any sort of straight line performance is going to require a lot of respect until at least the half way point of the run where you start heading up again.
  • 4 weeks later...
  • 2 months later...
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
