lcd leds or just a rear leds (button leds) ??
No I dont have but im pretty sure its somewhere on sau unless u talking bout lcd led
try this:
http://www.skylinesaustralia.com/forums/Co...l&hl=666dan
Edited by naomy
Damn its actually a wedge bulb type fitment for you?
The R34 GTT one is some weird looking bulb+base in one. I have attached a pic.
Haha dude Ive fitted it MANY MANY times, aircon LCD, aircon buttons, dash, triple meter, cigarette lighter, everything except for the ignition.
You cant pull that bulb off the white base, trust me I tried, its not a wedge type design.
And the glass bulb is pretty small, T5 sized almost
Im pretty sure they are T5 or T10 wedges, at least mine arent.
You're right nuffsaid.. it is a bulb in base design. So no wedge.
I had a look at mine, tried to pull it off to no avail. So what i did was smash the globe (harsh I know), and then wired the feet of the led directly onto the base. A bit of stuffing around I know. But it looks trick.
wish i took photos mate.. but i'll try to describe it as well as i can.
1. Following instructions in the first post, remove the steering column cover.
2. Twist to remove the bulb holder.
3. Using a pair of pliers remove/break the bulb.
4. Remove the bulb filament with the pliers, you should then see two holes.
5. Take your blue led bulb, and straighten the legs (two wires + & -) out on it.
6. Chop off the legs to make them shorter.
7. Reinsert. The Dan666 T5s supplied ones just fit the bulb holder, so once squeezed in they should be a really tight fit and unlikely to come out.
8. Test and then reassemble column cover.
Having said the above, I wouldn't really recommend doing it this way and a new wedge bulb holder type holder is definately the more reliable way to go.. so do the above at your own risk. Although it's just a led light, you do really end up destroying the bulb/holder in one thing by performing this mod.
  • 4 weeks later...
    • I don't like "actual computers" for in car use. They take time to boot up, have OS annoyances, and so on. Arduinos etc are ready to go a few seconds after power on, don't mind being agressively powere cycled, because everything is non-volatile, don't mind being shaken and stirred.
    • As Fred would tell us, it's all about interpreting the rules. It's not a water sprayer, it's a water mister... But everything else you've said, 100%! Even a raspberry Pi would be great, use HDMI out for a display, and add a raspberry Pi CANBus hat to read values out from the ECU.
    • Being a race car, and being in the era of the Arduino, one would think it would take little effort to build a controller to do the spraying based on a real physical measurment. Waaaaay back in the dim dark AS days, JE "designed" (as in, he had help) a microcontroller based intercooler spray system. It watched the difference between a temp sensor stuck on the core and one in the free air in front of the cooler, and if the temperature difference exceeded a (settable) threshold, it would activate the sprays. Thus, it only ran water when there was an actual need for water. If you stop to think about the actual physical things that are going on in that stack of coolers, there's probably at least a couple of triggering conditions one could come up with, and one could probably even run one pump with more than one solenoid valve, to allow water to be placed where it is needed, or at all points at once (if it is needed at all points). We're in the age of science baby. But.... I suspect that intercooler water sprays are on the forbidden list in most circuit classes, no? So only good for Targa type stuff?
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
