Hey guys , my business Kermit Engineering will soon be seeking new premises due to circumstances beyond my control . As soon as i can finish my current workload i will be leaving JSHOP and seeking new opportunities elsewhere . I am currently spreading the word of my availability to other performance workshops who hopefully appreciate the services i offer more .
So if anyone who knows me and my business knows of any businesses who could benefit form my skills could you please let me know .
In addition to my Fabrication and Welding skills i also bring a fair bit of performance related work with me as my customers continue to buy auto parts unrelated to what i offer .
Thank you
Sincerely , Mark Colborne
https://www.sau.com.au/forums/topic/214832-kermit-engineering/
Just some small matters to clear up for all you misinformed individuals.
1. J shop is not closing, we mearly held a liquidation sale to move some old stock that we wanted to get rid of. There was no mention on any forum from myself or Aston that we were intending to close doors.
2. Sn1p3r, if you have any problems with the work performed to your skyline please fell free to take it up with me in person rather than sledging jshops name. I'll be happy to take it up with you when i look at your car on Friday as per your booking.
3. All work performed before i started at j shop i cannot comment on, but i stand by my own personal work and will cover any warranty issues ppl have including parts or labour.
Phill - j shop workshop / sale manager.
She sledges your shop, then makes a booking for work to be done there?
*scratches head*
*scratches head*
Well if a shop didn't do it properly the first time id take it back too, not saying this happened or anything. Going back can be a real pain in the arse when its not supposed to happen
Happened to me at mettams mufflers
But i am sure these guys do great work
:P good luck
and then this....
Sorry if i have mistaken but where in this does SN1P3R "sledge" JSHOPS name? Maybe an apology? *SHRUGZ*
can you ship the cat back exhasuts interstate?(Sydney 2164)
P.S your inbox is FULL dude.
sorry mate , i cant ship anything over east . all my exhausts are custom made to suit the vehicle , building on a donor car is risky as i promise that all my exhausts fit perfectly . i suggest getting something built over east mate
kermit
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
