Engines Rb20 And Rb25det- Cusco And Zeal Coilovers Hcr32/er34-orc 409d Clutch Kit- Apexi Turbo And Nismo Caps And Knobs- Suspension Arms And Braces
Zeal B68,000kms, Springrate 10/8, 6 Damper, 2 Way Height, Pillow Mounts
No leak
For Nissan BCNR33 BNR34 ER34
$1450 in stock
Cusco Zero 2 - Springrate 10/8, 5 Damper, 2 way height 13,000kms
No leak
For Nissan Silvia HCR32
$1450 in stock
Cusco Zero-2-Springrate 11/9kg, 5 damper, 2 way height, 8,000kms
Excellent condition
For BNR32/HNR32
$1500 in stock
ORC 409D Single Plate HCR32
Brand New
$1200 IN STOCK
Genuine Apexi AX53B70 (370PS) - 9000kms, Stainless Steel Dump Pipe, No Oil Leaks or Shaft Play Guarantee
For Nissan Skyline R32
$1700 IN STOCK
HCR32 Manual box (just the box)
75,000kms
$1900 in stock
1994 RB25DET
87,000kms
$2000 IN STOCK
HCR32 RB20DET Engine, 90000kms
No Loom, but Turbo Attached
$1400 IN STOCK
uDrive40.jpgHKS Kansai Brace
For BNR32
$480 ETA end of April
Cusco Rea Toe Arms
Brand new
For S13/S14/S15/R32
$370 EAT early April
Cusco Traction Rod
Brand new
For S13/S14/R32
$330 ETA early April
Cusco OS Type Front & Rear Brace
$270 IN STOCK
Brand new Rear Cusco OS brace + used Cusco OS front brace for R33
$400 IN STOCK
Nismo Carbon Gearknob - Brand New
For Nissan Silvia S13/180SX/S14, Skyline R32/33/34
$130 IN STOCK
Nismo Leather Gearknob - Brand New
$80 IN STOCK
Nismo Rad Cap
For Nissan
$65 IN STOCK
Nismo Oil Cap
For Nissan
$110 IN STOCK
We will constanly updating new parts so please come back soon to check out new update :thumbsup:
IF WE DON'T HAVE WHAT YOU NEED, PLEASE LET US KNOW (CALL THUY ON 0422 422 344 OR PM) AND WE CAN SOURCE THEM FOR YOU- BIG OR SMALL FOR ALL IMPORTS
Regards,
J-Imports
  • 1 month later...
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
