NOW the very actual question: how to connect e-manage inputr (option 1,2) with lc-01 lambda sensor by innovate ?? the trouble is: options have 3 connectors, but we have only 1 connector from lc-01. pls help smb cause 31 of may we have to drag on Tomsk drag battle in russia ))
https://www.sau.com.au/forums/topic/214906-e-manage-maps/#findComment-3796903
If anyone has an RB25 emanage blue map that they could send me that would also be much appreciated :P
Winmasta - PM InterCooL, he has a wideband (not sure if it is an innovate one though) hooked up to his emanage. Might be able to help you out.
https://www.sau.com.au/forums/topic/214906-e-manage-maps/#findComment-3797377
thanks i will immidiatly
https://www.sau.com.au/forums/topic/214906-e-manage-maps/#findComment-3797552
hi mate
do you have emanage blue or ultimate
here are 2 threads for the ultimate
http://www.emanageforums.com/forums/showthread.php?t=199
http://www.emanageforums.com/forums/showthread.php?t=319
i use emanage blue and use 'sheps' alpha tools. note you have to have .net 2.0 framework for his alpha tools to work
there is some instructions and links here
http://www.emanageforums.com/forums/showth...;highlight=shep
all you have to do is take the single wideband output from the LC-1 and wire it to the AFM #2 input on the emanage blue
the AFM #2 input is the yellow wire in the top diagram as seen in the top picture here;
http://www.mohdparts.com/emanage/manuals/e...e-manage_10.JPG
then load up your laptop and calibrate it via the LM-Programmer and AlphaTools under settings
then you can data log rpm vs afm vs afr vs many other settings
then there's the third option, if you are using emanage blue, you can update to a 'gold' version
follow the tutorials from this first post here;
http://www.msprotege.com/forum/showthread.php?t=114417
after that you're on your own, i have not upgrade my emanage blue to 'gold'
but apparently you can use AFR input for 'target' tuning, it may use the exact same input as described above. but like i said, i'm not 100% sure with this method
https://www.sau.com.au/forums/topic/214906-e-manage-maps/#findComment-3798129
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
