NOW the very actual question: how to connect e-manage inputr (option 1,2) with lc-01 lambda sensor by innovate ?? the trouble is: options have 3 connectors, but we have only 1 connector from lc-01. pls help smb cause 31 of may we have to drag on Tomsk drag battle in russia ))
https://www.sau.com.au/forums/topic/214906-e-manage-maps/#findComment-3796903
If anyone has an RB25 emanage blue map that they could send me that would also be much appreciated :P
Winmasta - PM InterCooL, he has a wideband (not sure if it is an innovate one though) hooked up to his emanage. Might be able to help you out.
https://www.sau.com.au/forums/topic/214906-e-manage-maps/#findComment-3797377
thanks i will immidiatly
https://www.sau.com.au/forums/topic/214906-e-manage-maps/#findComment-3797552
hi mate
do you have emanage blue or ultimate
here are 2 threads for the ultimate
http://www.emanageforums.com/forums/showthread.php?t=199
http://www.emanageforums.com/forums/showthread.php?t=319
i use emanage blue and use 'sheps' alpha tools. note you have to have .net 2.0 framework for his alpha tools to work
there is some instructions and links here
http://www.emanageforums.com/forums/showth...;highlight=shep
all you have to do is take the single wideband output from the LC-1 and wire it to the AFM #2 input on the emanage blue
the AFM #2 input is the yellow wire in the top diagram as seen in the top picture here;
http://www.mohdparts.com/emanage/manuals/e...e-manage_10.JPG
then load up your laptop and calibrate it via the LM-Programmer and AlphaTools under settings
then you can data log rpm vs afm vs afr vs many other settings
then there's the third option, if you are using emanage blue, you can update to a 'gold' version
follow the tutorials from this first post here;
http://www.msprotege.com/forum/showthread.php?t=114417
after that you're on your own, i have not upgrade my emanage blue to 'gold'
but apparently you can use AFR input for 'target' tuning, it may use the exact same input as described above. but like i said, i'm not 100% sure with this method
https://www.sau.com.au/forums/topic/214906-e-manage-maps/#findComment-3798129
    • I'm seeing torque specs all over the place for the OUTER tie rod, but none for the INNER tie rod, where it connects to the steering rack. Even in videos, people are just tightening em up as much as they can with a wrench and that's it. Anything tightened down without torque makes me nervous. Anyone know what the spec is for it?
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
