Hey guys, im having a real deliema, i just bought some of this Redline shockproof 80w90 the red stuff. Now i have chucked it in the diff and gearbox.
The problem im having is that it still feels like my gearbox is really tight. As in getting the gears in. Sometimes they feel like they are crunching to get in.
What do you recommend for gearbox??? or should i stick with this stuff?
Also I can really smell this stuff its really strong inside the car. is that normal??
Also its for my 34gtt. and i also have a short shifter.
Cheers.
Edited by R34ZOR
https://www.sau.com.au/forums/topic/214934-redline-shockproof-80w90/
Cheers.
smell inside the car is not normal.. maybe you dropped some on ur exhaust? go wash it out at the carwash...
with the oil.. give it about 200-300kms.
if it is still notchy then there is an additive called Nulon G70 gear treatment...
if its compatible with your oil then you can give that a shot.
i just did a full service on mine and my gears felt notchy for about 2 days.. so drive gentally.. its now smooth and soft..
i guess it takes a while for the old crap to come off the gears..
hope that helps buddy.
Avi
Avi
hey mate, yeah i have driven about 400km now. with the new stuff in. When ever I give it hard shifting or boot it, it is a really really strong smell in the cabin 100% its coming from the gearbox and up through to the cabin.
  • 1 month later...
Firstly check the plugs are in & sufficiently tightened but not overtightened as they are a tapered thread, I have just done this service myself and used thread tape when replacing the bungs, as a matter of interest to any who read this thread I have used Penrite SIN 75w-90 in my box(RB20DET) and noticed an immediate difference in gear changes(being smoother) and a lowering of transmission noise inside the car. I will be trying the lightweight shockproof next to compare so I will post those results when that happens. I will be doing Diff change 2mrw and fitting large swaybars at the same time so will keep you all posted
    • Did you get the sport or track ? From what the documentation says the uniclutch has a small amount of movement to disengage.  So your story of tricky pedal setup seems common.    Hopefully you got it bled up too, as the bite point moving around is usually either plates wearing in or air in the line.
    • There's always "MIG it up and grind it back".
    • Hey everyone, i have quite a few of these now and looking to sell my collection.    There’s many different brands and they all say something similar when powered up. if you would like an example of what they do and how they work i suggest searching JDM ETC READER into google or youtube.    I know some people dont like them but others want that final “JDM” piece for their project.  Below are a few examples of what i have.  feel free to contact me if you want more photos or have any questions. i also have a few that dont make noise but just light up to give the aesthetic.   $80 ea or will do a good discount if multiple are purchased. Located in South Australia and happy to post interstate if required! Thanks for your time!
    • I hope so.  It seems pretty nice. OEM feel the lot.
    • I wouldn't be surprised if this helps. And I wouldn't be surprised if it keeps changing for a bit after the new slave&hose go on, because I find that my clutch always does this sort of shenanigans after any serious dismantlery. And then it settles down after a few corrective tweaks such as you've already done.
