Hey,
Just wondering what the difference is between the Pillar Gauge holder from EBAY and the Pillar Gauge holder from JustJap? The one from EBAY cost $18, 52mm, and says its made of plastic and will fit R33/R32/Silvia. The one from JustJap cost $140 and says its a Trust brand and 60mm Gauge holder. The JustJap one is also avaiable for R32/R33/Silvia. Just wondering if anyone knows the difference? Does the JustJap one fit perfect? or is it made of wood?
If the JustJap one is the same kind of plastic gauge holder i dont see the point?
Thanks!! :P
Oh ive also wondered how you would attach the gauges to there holders? I cant see how a gauge would be held or mounted?
Edited by R33Matt
not sure about these two specific ones. but i had a similar holder in my r33 and it kinda fit, but the guy only held it in with one screw.
they shitty speco gauges he put in it kinda just sat in there with no help, they were reasonably tight though.
i found a generic cup holder with stand a friend had and modded it to fit the gauge i had and got rid of the anoying pillar mount
if you can mount your gauges some other way i recommend you do that
I've seen someone else trust pillar double guage holder, I expected to find a nice snug molded fit but it was not, not what I expected...
I would go the dash mounted ones myself...
Hmm....
yeah I could do the cup holder really easy! Plus they only cost $10 each! lol, I guess the cup holders if put neatly look pretty good....
But was interested in the Pillar Mount becasue i thought it looked a bit more Professional. Some skylines ive seen with Pillar mounts look really good! some look like it was there stock because of how neat its been setup.
Your gauges were floating inside the Pillar mount? lol, Crazy! lol
Hmm....
haha yeah i could pull them in and out and twist them around. dodgy wiring also. all fixed now though :P
if anyone wants a pillar pod i have one for you :P
Well after much thinking i decided to put the gauges under the deck! At first i didnt think they would even fit, but after a quick look with a boost gauge it fits easy!! Could easily fit 3, 52mm gauges in there. So gonna make up a metal plate this week to hold 3 gauges, paint it black and slap it in. Should look really neat and nice!! Wasnt keen on putting screw holes in the pillar or on my dash. Gonna put up pics this week of the install and steps of what i had to do if anyone is interested :)
  • 2 months later...
Well after much thinking i decided to put the gauges under the deck! At first i didnt think they would even fit, but after a quick look with a boost gauge it fits easy!! Could easily fit 3, 52mm gauges in there. So gonna make up a metal plate this week to hold 3 gauges, paint it black and slap it in. Should look really neat and nice!! Wasnt keen on putting screw holes in the pillar or on my dash. Gonna put up pics this week of the install and steps of what i had to do if anyone is interested :bunny:
pics plz :D
im also thinking about where to mount my boost gauge.
i will only be using a boost gauge, no other aftermarket gauges, so the pillar mount was out of the question, then i decided to mount mine under the cd player aswel, but i got my greddy turbo timer in there, so im gonna make a templet for the the boost gauge and turbo timer and get a piece of black acrylic cut out and mount them on that.....neat and easy
what brand 2" boost gauge do yoiu guys recomend? sumfin for around $80 ??
    • A few more recent pics
    • full send the cnut, do this   fark the wrapping and/or stick on siet. These guys are the ones to go to: https://www.realthermo.com.au/
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
