ok so i finally got sick of the skyline coils and set up a wasted spark conversion using the 3.8 buick coil pack(new) and bocsh ignition leads(new) on my recently rebuilt Rb30det GTs4.
one advantage to this is now i can use a timing light to check the timing.
the disadvantage now is that when i have the timing light on the number one is firing about 10 millimeters past the last mark on the harmonic balancer.
or around 32-35 degrees past where it should be...
ive tried resetting the ecu, tinkering with the cas(but it limited to how far it can turn).
i even took the cam belt of and advanced the exhaust cam by three teeth to compensate for the retarded timing but to no avail. it still runs like dogs balls.
any help would be apprieciated, i'd hate to think i have to go back to the individual direct fire set up...
https://www.sau.com.au/forums/topic/215013-rb30det-with-wasted-spark/
Have you checked that the harmonic balancer hasnt spun?? thats usually the cause of timing marks way around from point.
also you can check timing with light on a indiviual coil setup there is a wire loop up near the back of motor you put the clip on
yeah i realize that, and no it hasn't spun the mechanical timing is fine.
its just the electronic side of it.
i undid the three bolts and turned the it around till the light it the marks and it runs fine as revs fine as.
only problem is its that far around ya cant bolt it back on.
double reading is correct how ever
nethier 1 or six, or any of the light pulses land where the should when the should.
when the CAS is bolted in place.
it would read like it was running twelve cylinders, each cylinder fires twice per revolution rather than the direct fires one.
had some success. pulled out the spark plugs and gapped them to .8 of a mill.
brought the timing back a bit but still not enough.
Changing the plug gap wont make any difference to the timing, and wasted spark will still run the same timing. Its in the conversion to wasted spark where you have got the problem, what ignition module/igniter are you running? Souds like you have it triggering off the leading edge of the pulse instead of the trailing.
helilujah. its a new coil pack and leads that would normally go on a 3.8 litre vt holden vommodore.
the question is how do i get it firing from trailing edge?
oh its running my old hks f con pro, r32 igniter gtr 6 speed box, gtr intake 90 ml throttle body , custom exhaust manifold garrett 35/40 teal 40ml waste gate hks step 2 cams bocsh 740cc injectors, in a 92 gts4 shell. just stuff i had lay'n around
after i bought my god
Edited by nizmonut
Make sure the igniter is earthed properly (bolted down, maybe with a proper earth wire connected also), I've heard of them severely retarding if not earthed properly.
To move the timing to where it wont bolt, you need to take the CAS off, turn it as far as you need then put it back on
ok. so was the car running fine before you did the wasted spark modification? or does the car still run ok but you are getting a funny reading?
to change weather it fires from a leading edge to a falling edge is in the ecu setup, and it all depends on the cas disc you are using, some are leading edge discs and some are falling edge cas discs, i believe the standard RB ones are falling edge.
got it sussed out, talked to the local auto sparky about it and he gave me a diode to solder in between
what would have been number one trigger wire and number six trigger wire.
so the sensor wire that ran from number one coil on the original setup to the ecu is still connected with
it s number one cylinder trigger wire,
but before it joins the number six trigger wire on there way to the shared coil the diode has been installed to stop the pulse from number six from upsetting the signal....to the ecu......
ya'll understand that
Number one trigger wire from igniter>>>>>sensor wire joins>>>>>>diode installed here>>>>>Number six trigger wire joins from igniter>>>>>>>both join coil
thats the best i can explain it with out pulling the online colins world dictionary.
  • 7 months later...
THE DIODE IS STOPPING ANY FEED BACK DOWN THE OTHER ECU SIGNAL WIRE! YES SIMPLE FIX. GOOD THOU.. IM BUILDING A BRAND NEW IGNITOR PACK FOR ALL S2 MOTORS
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
