hi all i have just done a compression test and the results were as follows
1)145 psi
2)150 psi
3)145 psi
4)146 psi
5)0 no needle movement what so ever
6)150 psi
What do you guys think has happened.
I am thinking a valve is open in cylinder 5.When the engine cranks over you can hear a consistent noise out the exhaust like a open valve noise.But could there be a piston problem.
Does anyone estimate the price of this job or has anyone had this kind of work done and what is the worst case senario
https://www.sau.com.au/forums/topic/21503-piston-or-valve/
Hi qikr33, check the valve clearances that will tell you if it's a valve. What you have done is called a "dry" compression test. What you can also do is a "wet" compression test. Squirt a fair bit of oil into the cylinder and check the compression again. If there is compression then it's pistons and rings, if there is still no compression then it's valves.
Hope that helps
https://www.sau.com.au/forums/topic/21503-piston-or-valve/#findComment-454867
