hey all, as some of the tassy boys will know, im building up my hybrid 25/30DET as we speak. Now i am stumped as to what turbo to use. i am aiming for 300+rwkw and the car needs to be streetable. it prob wont be my every day car but will be driven on the road often.
so a big laggy sucker isnt really ideal for me but in saying that i dont want a turbo thats too small and has no punch.
Responsivness is prefered but would like to have a bit of punch on boost.
The engine specs are as follows:
rb30 bottom end
knife edged stock crank
shot peened standard rods with arp bolts
wisco 20 thou over pistons
acl race series bearings all rond
ported and polished rb25det head
stock cam shafts
new/upgraded springs and valves etc
after market ecu (unsure what one yet)
bosch 040
500cc injectors
z32 afm
forward facing plenum (unsure what one yet)
fmic
3.5 inch turbo back exhaust or there abouts
Now i will be chucking the turbo on a high mount manifold with an external gate and hope to run about 18 psi.
would like to hear what turbo setup you guys recomend for me as my knowledge in turbo selection is lacking lol.
cheers james
https://www.sau.com.au/forums/topic/215037-what-turbo/
  • Replies 41
I dont think you can go wrong with anything around the GT35 range (either a GT3540 or something slightly smaller, GT3240), they will easily give you the power you want (rated around 600-700HP) and beyond and being a 3L this gives you the displacement to spool it up quickly.
Quick edit: Just noticed you have 500cc injectors, are they actually 500cc or nismo 555cc injectors? Either way, if you want to go much over 300, say 330ish, id probably recommend 740cc injectors just so you arent running the 500cc on such a high duty cycle.
Edited by PM-R33
https://www.sau.com.au/forums/topic/215037-what-turbo/#findComment-3797325
point taken.. i will look into bigger ones
https://www.sau.com.au/forums/topic/215037-what-turbo/#findComment-3797353
to4z... bit big maybe???
i assume displacement should be quite close to 3 liters??
600x300x75 we will say for now about fmic (havnt purchased yet)
exhaust and fmic will be 2 of last things i get as i want the piping to have clear path so will install motor etc first.
Edited by tm_r33
https://www.sau.com.au/forums/topic/215037-what-turbo/#findComment-3797356
you do know that the T04Z comes in a range of rear housing.
you would easily make good power and responds with the 63T A/R0.61 on a 3L
sorry this means not heaps to me... please elaborate in dummy language lol
https://www.sau.com.au/forums/topic/215037-what-turbo/#findComment-3797411
what is the .61 actually a measurement of??
before this thread i was leaning toward a gt3540 and seems maybe still the way to go??
am i right inassuming .81 is a bit big if response is desired???
excuse my ignorance guys. never had to look into bigger than standard turbos before
https://www.sau.com.au/forums/topic/215037-what-turbo/#findComment-3797434
Nope.One is a 3040 the other a 3540
3040 is about a 600hp turbo
3540 up to about 750hp depending on housings.
Wouldnt go smaller than an .82 on a RB30
so the one with the .61 is actually a gt3050 not a 3540???
and the one with .82 is the 3540???
https://www.sau.com.au/forums/topic/215037-what-turbo/#findComment-3797754
