  • Replies 108
shit only map i could find
someone edit this so that we start at citywest, i got work now till bout 9, so i cant come back to check this thread
so i can't print either ( didnt mean to be cheap haha)
i'm gonna call Andrew if i don;t get to citywest by 9. (stolen ur number from your for sale thread :) )
and yeh i;ll take u for a spin Chi. shouldn't be much different to your car lol
someone with free time edit and type this up and print it!!.
if the cruise gets canceled or postpone someone msg me on 0431 041 923 plzz!! lol
if it's really really really busy at work im might not be able to come :(
Edited by ztuned
yep, i'm going to fix up the maps now...
meet at 9pm, leave 9:30
OKAY EVERYONE CRUISE IS GOING AHEAD, MEET AT 9 AT CITY WEST
LEAVE AT 9:30
THE GUY WITH THE SNOW PLOW R34 WILL BE HANDING OUT THE MAPS, HIS NAME IS ANDREW AND HE DOESN'T BITE
COME CRUISE TONIGHT!
i might come but i doubt it as id rather go out and get drunk...anyway im not sure yet but probably not...
me and you both buddy!!! :wub:
Good luck on the cruise though guys, my car was twitching all over the place on the way home just before - try and be safe!
ALRIGHT MY LAST POST BEFORE DINNER AND BEFORE I HEAD OFF...
CRUISE IS ON, I'VE PRINTED ENOUGH MAPS, I'M NOT EXPECTING A HUGE TURN OUT WITH A TINY BIT OF WETNESS AND SUCH SHORT NOTICE BUT IF YOU'VE GOT SOME SPARE TIME COME DOWN AND HAVE SOME FUN WITH ALL OF US
MEET AT 9PM - CITY WEST
LEAVE AT 9:30PM
LOL i can't believe the cruise is going to go ahead, was just an idea me and another member had in our heads like two/three days ago :wub:
HOPE TO SEE YOU ALL THERE!
i messaged her before, she said she's definately coming down...
just call her man lol
be good if i had her number...lol
care to pm it to me or send her mine?
Edited by A31StRuCK
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
