hey everyone,
let me set the scene.....recently my car has been makin noises, like the car is struggling, but can only been heard through exhaust..
now, it only happens after about ten minutes of driving (when the cars warmed up) and usually at low RPM or when the cars travelling at below 60....anything above and the car sounds fine..
my initial reaction was that the spark plugs were going, so i got a service and tune and the guy siad mechanically its fine (engine wise) which leads me to the conclusion that is an exhaust fault...
would this be the cat converter going on its way out?
has anyone had similar problems?
i have to drive to melbourne over the long weekend coming up so i wanna make sure its running perfectly!!
thank you!!
https://www.sau.com.au/forums/topic/215088-is-my-cat-converter-on-its-way-out/
an exhaust shop will be able to give you a proper diagnosis.
tap the cat to see if bits are rattling.
cheers mate
the only day i have off is sundays and no exhaust places down my way are open then, so time management is an issue.
plus, if i take it to an exhaust place without knowing myself what the fault is then im more likely to get scammed.
(if i go and say i THINK my cat is going, they will just replace it whether it is or not...haha)
i tapped the cat converter and couldnt hear anything rattling..
may be starting to block up tho
Thanks :wave:
what kind of noise is it?? the components in an exhaust (cat & muffler) do degrade after a while, and especially so if you've been running rich
if you are able to, unbolt the cat and have a look for yourself
why not just unbolt the cat....if it is flanged that is.
its a 10min job. and u can be 100% sure on whether it is the problem
You may need to soak the nuts and bolts in WD40 for a while.. And breaker bars are a good idea too. Save yourself a whole heap of effort, trouble and problems..
Edited by GTS4WD
Correct me if i'm wrong, but i don't see why a rooted cat would be restictive at low rpms and get better at higher rpms. Wouldn't it be crap regardless, and more so at higher duty?
Does the car backfire often?
Anyhow, it's better to eliminate it- so pull off the cat.
you say it starts struggling 10mins into the drive... do you get the "check engine" light? if there was something truly wrong with the exhaust im sure the "Exhaust" symbol would light up
yeh it seems to be after the car has warmed up....for example, i could be parked at the lights and it feels like the cars dropping out but only for a split second..like, the RPM gauge will go from 1000RPM to 700RPM then back up within a second, but it does that continuosly until i reach above 80kms an hour.honestly it is so hard to explain so sorry for the confusion..
i just got the exhaust put on, like in a matter of two weeks..
its been through services and tunes, so i know it isnt running rich, thats why i am assuming its the cat, but the Symptoms (so to speak), are a bit different than usual cases...
Yet to take cat off,but will friday..called in a sicky!!! :P
cheers!!!!!!
I thought when the cat's going, it rattles when the car is cold, then stops when it has warmed up? Thats what mine is doing, although when you hit it, it doesnt rattle. I'm very confused now... I've lost so much power, and the car feels restrictive to drive, and it all happened around the time the clicking started. Any ideas?
i get a rattle in mine when its cold but when warmed up its fine it happens between 2 and 3000rpm ill probably take it to an exhaust shop for them to look at it and see what they think. but then ive herd its normal for N/A r34's like how N/A r33's have that rasp.
update............
ok, this is really really annoying me...
been to the mechanics twice, paid for two different services and the problem still exists..
my r33 is misfiring, at low RPM and at Idle....does anyone know what could cause this...the longer i drive it, the worse it gets
- i have already got the spark plugs checked, ECU, Catalytic converter, full service and tune, O2 sensor checked, solanoid, basically everything....now, im due to go to the mechanics 2moro, but they are saying it may be the fuel injectors....
where as im leaning towards a vaccuum leak, hence the reason the misfiring is consistant during idle...
has anyone had similar problems...need help!!!!!!
Edited by NFSR33
have you checked the coilpacks, it might be that.
agreed, i'd check those before injectors...
coil packs seem to be failing quite regularly now days that skylines are getting older.
remember that these cars are over 10 years old and yet we expect them to perform as if they have just come off the showroom floor.
update time....
so i took it down to my mechanic....got it looked again...(3rd time)
told him that i CAN only be two things, injectors or coils...as every other alternative has been checked and disregarded...
low and behold, its the coils...
but the bad thing - the price - $850 for set....
HOLY SHIT!!! :)
haha
car is booked in once again, for monday to get coils done..
will update if the problem is resolved...if not, get rady for alot of curse words.. :O
WHATEVER COILPACKS YOU'RE BUYING DONT BUY THEM!!!
http://www.skylinesaustralia.com/forums/Sp...99-t188698.html
splitfires for $499... doooo eeeeeeeeet!!!!
glad we can help
$499, for spitfires for an rb25de?
F U C K...!!!!!!! sorry about swearing
ive already got em ordered, exact same ones for $850 fitted..
im p'd off.... :down:
damn, i shoulda posted em earlier, woulda saved myself considerable amount of $$$
thanks for the help!!
and for makin me look retarded :) hahah kiddin..
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
