Hey guys been havin a bit of trouble with my car.
When at a stop car has a horrible idle, any where from 900rpm to 100 or stall.
Have cleaned aac valve, stock plumb back bov, had a different afm on there (tho was old and could have been crap)
I am buying a new fuel pump this week as well (if that has anything to do with it)
Does any one have any ideas what this could be?
Thanks for replys in advance!
https://www.sau.com.au/forums/topic/215162-out-of-ideas/
did it only start playing up since you cleaned the aac valve? idle may not be adjusted properly
did you also clean up the cold start valve? thats the one under the throttle body.
also sounds like its a good possibility you have a vacuum leak.
https://www.sau.com.au/forums/topic/215162-out-of-ideas/#findComment-3800153
I dont really know what maintenence has been performed on the car but if it were me I would be starting with the spark plugs...pull them out and check general condition gaps etc..then as I am reassembling all that I would pay close attention to the coil packs, any corosion on the connection where it meets spark plug ? squirt of WD40 may help.....good starting point as I am thinking if its a fuel issue you would have problems under load.....Unless you got a partially blocked injector or something...but start with the spark...I think the problem is there
https://www.sau.com.au/forums/topic/215162-out-of-ideas/#findComment-3800160
it also stalls if slowing down to a stop and i put the clutch in sometimes. its more hunting then anything (can see the boost gauge rise and fall on vaccum??)
https://www.sau.com.au/forums/topic/215162-out-of-ideas/#findComment-3800179
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
