Hey all,
First things first.. Engine is an rb25/30 with an externally gated garrette t04e, power fc and the other usual mods running a wasted spark setup that I finished installing on sunday. Car was running fine before the wasted spark, and was running perfectly fine after the wasted spark for about a day.
I first noticed the misfire after boosting out of a corner and had the usual low fuel misfire, so I went and put in 5 litres of mobil regular premium to get me to a decent fuel station.
Pulling out of mobil the car was running fine again till about 5 minutes down the road where I again boosted at which point the engine completly cut out, it was as if somebody had unplugged the igniter pack, 100% misfire.
I pulled over to the side of the road and tried to start my car but it wouldn't. I left it 5 minutes and tried a few more times, the last of which she turned over perfectly, not struggling to start at all. I thought this weird and decided to turn home to stop myself getting stranded and found that as soon as I touched the accelerator the car would misfire, much the same as a set of dodgy coil packs. By the time I got home I could only let the car idle in 2nd gear as as soon as I touched the accelerator she would misfire and almost stall.
At first I checked the usual things, ignition is fine when the misfiring occurs as is the timing.. Car didn't seem to be blowing any black smoke during the misfire indicating perhaps she was running lean. At this point I'd also like to point out that at no point was the car knocking on the drive home (power fc with fc datalogit hooked upto the laptop datalogging :thumbsup: so I started to suspect that it may be a dodgy fuel pump, so I swapped it out with a brand new 040 I had laying around, however the problem persisted.
It does seem weird that the problem started after installing the new wasted spark setup (3xchampion bomb0d0re coils with stock r33 igniter), but the car did run fine for a period after installing them
I've now checked all sensors and they all appear to be reading fine, and I'm at a loss for what else to do.. any thoughts or idea's would be greatly appreciated :)
cheers,
marcus
https://www.sau.com.au/forums/topic/215180-mysterious-misfire-s/
jeeze, does not sound good mate.
I know this is a long shot, but for a time I had a miss firing problem too, which was not as severe as your case, but at some points it got close. I bought all new sparks, splitfire coils, etc etc.. I was almost going to buy a new harness to plug into the coils.. but Nissan wanted over 300 for that!
turned out, it was very simply... a small rubber hose that had a considerable crack in it at the bottom of it... changed it over for 8 dollars and my problem was solved!
as I said, I know its a long shot, but you sound as though you have exhausted most other options.
Good luck with it mate!
Adam
this may also sound stupid, but it *could* be your AFM playing up.... What did datalogit say about AFM voltage at the times ? If your seeing really large spikes when you touch the throttle, could be AFM being stupid and causing the car to dump a tonne of fuel and subsequently missfire/die. Also check TPS & CAS ??
thanks for the replies guys
yeah i'll swap out the plugs tomorrow for some spares i've got laying around, else i think i'm going to grab the stock coil pack loom off a mates wrecked 33 (i butcherd mine making the wasted spark :P ) and whack the stock ignition setup back in there.. just seems too suss that this problem would arise a day after changing to the wasted spark.. must've triggered something somehow.. will also check the afm voltages again, but i didn't see any rich smoke coming out of the exhaust :) anyway keep the idea's coming, thanks heaps guys :)
I know it might be a strange suggestion but did you check your fuel pump? was it priming when you had been trying to turn it over? could also be this if its not the fuel, perhaps carry around some fuel cleaner from now on?
Reason i mention fuel, it could have cut fuel giving simlar feel to misfire jerking and since it actually stopped its going to be either of the two. Just throwing it out to you.
Edited by DECIM8
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
