  • 5 months later...
  • Replies 75
In regards to what JiVE said:
"And if your after the 'flutter' sound this can also be acheived through the stock bov. Just get a POD and pull the vacum hose out of the BOV. Make sure you block it off real good however, or you will stall."
Have any of you guys actually done that? And what is it about that that would flutter? I've heard of the fluttering before, but i don't know what causes it.
And what sort of effect would this have on driving and safety of my engine and parts?
Is that safe? isnt that making the BOV useless?
If you want the pppsssshhh sound just install a pod filter. Some are quiet loud and they wont cause your car to stall & back fire... (Make sure you get some sort of cold air box with it though...)
Thank you all for your responses.
Scanning 500+ pages of the manual and converting to pdf...would take a while. I want to scan it anyway so I don't get it dirty when working on my new girl ;)
I know some of you think that a bov is surpurfulous, I don't want to get in trouble with the cops either, I just love the sound :D I have enough dramas with the cops in my N13 pulsar GL :cheers:
Looked at ROH 17" Fury wheels for my car today. $2300 inc tyres. Gees, things have become expensive, it's been about 5 years since I've bought stuff like this, I am really out of the loop.
When i Installed my Blitz BOV i had to take off the stock BOV and replace it with a metal plate to seal off the hole. I did the test without the BOV hooked up and the Flutter sounds great.!!
I also found with the adjustmant screw on the Blitz, at low boost i could make the same sound.
Unsure if it will work if you just unhook the vacume line... as there is a small hole in the stock BOV that bleeds pressure off..... No idea why....
I just took off my stock rb25det bov last night to replace it with GFB Mach 1
its gone on no problems, but the recirculating pipe back to turbo, or the rubber tube that covers the old b.o.v so that it goes to airbox is now left open...
i called gfb to get the rubber BUNG to plug it up, but i started car last night, & yea it was idleing fine, but when revved, it started to sound as though it was chugging along,
the bung is being delivered to me today my gfb, but can i still drive to the ervo in it for milk & bread & shit, or THE PLUG MUST BE IN PIPE?
Tight fit.... or should that be "toight fit mate"... anyway
It was similer size to the rubber hose and slotted in, i just did the clamps up real good and tested with bag to see if there was any pressure loss... (none of course)
There's a website that reckons you can modify the stock BOV to be able to handle 30psi without leaking. Not 100% sure if it's the same BOV as the stock one in a Skyline but it looks very similar, maybe you could try the same thing?. Go to http://www.thedodgegarage.com/turbo_bov_mod.html
Find the 'recirculating valve' that will be attached somewhere between your compressor outlet and your throttle body (if your car already has one). The cheapest way to make this vent to atmosphere (pssh) is to:
* disconnect and plug the return hose
* put some type of filter over the "new" outlet on the valve.
Note that with an AFM car, you're now dumping air which your meter(s) have measured...
Regards,
Saliya
  • 6 months later...
Does the GTS25t has its own standard BOV or BPV? Im planning to install a bov after market bov. Is that a good idea?
Hey buddy, your beautiful line already has a highly effective BOV from the factory!!
You'll do well to keep it! (unless your planning some other seriously insane power mods!!). Cops won't hassle you as much either, I guess! ;)
You'll do well to keep it! (unless your planning some other seriously insane power mods!!). Cops won't hassle you as much either, I guess! :)
What i meant was whether the auto uses a BPV or Bov cause i saw em in another thread about it
  • 1 year later...
I am considering to put in a HKS SSQV BOV with the whistle sound.
I'm aware of the fact that it'll attracts cops.
But as long as i drive like a turtle and change gear at RPM 2000 odd, the BOV will not sound (correct me if I'm wrong).
I just like the "whistling" sound from the SSQV. that's y i'm considering to get it.
in terms of running richer, is true. But tuning is all about getting it to run at optimum (correct me if i'm wrong again).
:worship:
    • I'm thinking that this is such a small part of the problem that you could easily forego the vac pump and just achieve 90% of what you need, which is keeping the gate open when off boost. It's not as if there are not already techniques to keep a gate fully closed under boost. After all, you have boost. Just use a wastegate actuator that will allow you to apply the boost on the appropriate side, just like every external gate out there.
    • Heres another fitment photo. redrilled the pattern to 5x112, and threw my audi´s rims on. had to touch the upper control arms with grinder, because the "sharp corner" was sticking about 2-3mm on the tire path. i have the "fender lip" mostly cut off, otherwise these (too) would contact with it. 20x9.5 ET25 rear    265/30 20x8.5 ET20 front    255/30 they are temporary, and look too big for the chassis. searching for 19s to it.
    • From experience, it will come back to bite you haha.
    • Background: my BMW 225i hatchback (rebodied MINI/X1) came with 3x RE003 and 1x Goodyear Asymmetric something. The RE003 roared and slid around, the Goodyear side was quiet and grippy. Definitely my car was thrashed before it got sent to dealers. My brother also got RE003 all round on his old VA WRX STI, I wasn't impressed with them, car was loud so can't comment on noise. Anyway, Hankook stopped making/updating V12 Evo2. So bought S1 Evo3 runflats. Great daily duties tyre and not that harsh ride. Tyre reviews site/youtube rated them as best stopping in the rain and I believe them. Next set, Goodyear Asymmetric 5 non-RFT. It beat PS4 in tests and is like $100 cheaper, so put them on. Great tyre, more grip then S1 Evo3 but a tad noisier as expected, still rocking them. Next set I am looking to go runflats, probably the new Hankook Evo. Although the new Pirelli PZ5 did well in tyrereviews test. Or go Goodyear Asymmetric 6 which was top tyre last year. The V12 Evo2 on my gen5 Liberty GT wagon did great in cold condition (drove to snowy mountains for a day so my husky can feel his ancestor's roots). Super impressive performance for $120 each lol. Never skimp on tyres, brakes, suspension. There's old pics of my R31's crappy random brake pads bending in the caliper at Oran Park track day somewhere around here. Anyway, my 2 cents.
