Hi all!
The other day when i started my car it was more of a pig than usual when cold. I kind of fobbed it off and just thought she was having a bad morning and sure enough, got to temperature and all was fine... however every cold start after that (3 starts) it got worse and now it wont even start. I haven't done anything to it the last few months. The last thing i did do was replace the spark plugs about 1000km/s ago so doubt its anything to do with that. Anyway i have probed the ECU with NDS and i get code 55 (no errors) and i can’t for the life of me figure out what’s happened. The last time it started it wouldn't even idle, it would stall, but start straight up again. Foolishly when i got time to do some diagnosing this week i hit the reset ECU function in NDS and since then it hasn't started. Now i don’t know if that’s related or whether it wouldn't of started any way. I have checked AFM’s they seem fine, i have checked as many hoses as i can, i have checked coil packs (splitfire 2000k/m old)
It gets a bit of a kick when trying to start. There is a faint smell of fuel as well.
Any help on this would be greatly appreciated.
On another note I’m looking forward to watching the R35 GTR this weekend in Targa TAS... i'll grab a few snaps!
Cheers
Andrew
https://www.sau.com.au/forums/topic/215198-gtr-wont-start/
Hi all!
The other day when i started my car it was more of a pig than usual when cold. I kind of fobbed it off and just thought she was having a bad morning and sure enough, got to temperature and all was fine... however every cold start after that (3 starts) it got worse and now it wont even start. I haven't done anything to it the last few months. The last thing i did do was replace the spark plugs about 1000km/s ago so doubt its anything to do with that. Anyway i have probed the ECU with NDS and i get code 55 (no errors) and i can't for the life of me figure out what's happened. The last time it started it wouldn't even idle, it would stall, but start straight up again. Foolishly when i got time to do some diagnosing this week i hit the reset ECU function in NDS and since then it hasn't started. Now i don't know if that's related or whether it wouldn't of started any way. I have checked AFM's they seem fine, i have checked as many hoses as i can, i have checked coil packs (splitfire 2000k/m old)
On another note I'm looking forward to watching the R35 GTR this weekend in Targa TAS... i'll grab a few snaps!
Cheers
Andrew
your igniter plug has worked loose due to the fact you did not plug it back in correctly when you did the plugs. Now your plugs are fouled due to trying to start it. Replace your plugs again and make sure the igniter plug clips home properly.
https://www.sau.com.au/forums/topic/215198-gtr-wont-start/#findComment-3800833
Ha! DiRTgarage, i think you're spot on! I didn't think about pulling the plugs out becuase they were so new.... a little digging round and i found that i i had forgotten to earth something... not sure what it was but i definately forgot to earth something near the ignighter. So i pulled 2 plugs out and they are both as dirty as 2 dollar (you know what) They are as black as black! Damn they were $27 iritop 7's too. I'll replace tomorrow and let you know.
Cheers,
Andrew.
https://www.sau.com.au/forums/topic/215198-gtr-wont-start/#findComment-3800926
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
