hahaha, yeah i cant wait till the engine is done, money is the real issue though, its gonna cost me heaps, so its gonna be a slow project. but will be well worth it. Im aiming to have it done early next year.
  • Replies 71
yeah it does, ive got it flanged so i can put a replacement pipe in. That makes a real difference, once the car hits 3grand it just moves, with the cat on it kicks in from about 4500rpm, im gettin a custom track exhaust, from extractors will split in to 2 11/2 inch pipes and exit at the side :D will make a hell of a difference i reckon
yes an NA car does need a certain amount of backpressure but this is already happening through ur headers and the rest of the exaust system, gutting the cat deristricts the exaust a fair bit and is definately a noticable power increase, those extractors where 285 bucks plaus 150 for fitting, the most worth while mod i have done yet.
by keeping the exhaust at 2 1/2 it keeps the back pressure at a good level, gutting the cat is illegal of course and it does screw things up abit u have to gut it and put a stealth pipe in it, visible as a cat, but its a pipe inside a box. my old zorst was 2 1/2 all through
i've got an auto r33 - but its the 5 speed auto version with a really short 1st which helps acceleration - i get around 7.5-7.8s for 0-100 - i've god k&n pod filter with divider in the engine bay, that's it (running 98 RON petrol all the time and service every 5,000 with anti-friction oil - i reckon it helps!)
i beat a wrx with a bov one night - that was pretty funny i think the guy was a sh!t driver tho, and i can keep up with my mate's ca18 silvia (rebuilt and boosted to 12psi)
8.2 sec is a bit slo for a '33 - even an auto - do u torque brake?
i think its slow too!
i wana go against an r33 with the same mods or less and see how i go..
do i torque brake?
i duno wat that means
but if u mean start of with ure foot on ya damn brake and on the gas and take it of brake
then yea thats wat i did to get that time.
try doing a 0-100 with the stock wheels, since i put my 17's on it has lost a little accelaration (diameter is slightyly bigger) i got 225/50/r17 on mine, if urs are 45 or lower then it really shouldnt make a difference, but tyres and width can also make a difference. u lose out on speed but handling gains heaps:)
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
