  • Replies 71
well supra dude ur actually right, the car will beat our cars but its the driver that has to be able to use the car to its max capability! neways fords suck and skylines rock ps my dads got an M3 i think that would easily kick ur dads XR6 turbo with out even using 1st and 2nd gear haha
Its nice to see ur dad has turbo charged ford. Bout time ford realised what the japs have known for years on how to keep an engine light and still get good power out of it. But the fact is that no one here really cares how fast ur dads car is, i would be prepared to put my car on the line if you or him could keep up with me round Mt Glorious or somewhere similar if i felt like i had something to prove. If u have nothing better to do then to come on a forum and try and stir something or get a reaction u must lead a very boring life, maybe one day daddy will let u drive his car and then u'll have something better to do to fill ur time.
haha, it must be something like that.
newayz, back on topic, i hated my stocko rims, they were the first things to go. Umm i dont really know what else it could be, have u run it down the strip yet? how long u had the car? did u find it went better when u first hopped into it?
I havnt taken it on the 1/4 yet..
Ive had it for just over a yr and its always been like this, got it with 91km on the clock.
And yeah the only time i noticed any power increase was the night i installed my pod filter on a reallly cold night and took it for a spin that nite..
other than that i really didnt notice any real improvement over the cat back exhaust or filter.
thats wat i think anyway
unless im just paranoid :D
    • As GTS mentioned, it takes a bit of faffing, some fiddling and a little modifying.  With the strainers, you can buy different styles. Some sit flat on the pump, some angle down.  Here are some photos of mine, ignore the ugly welds lol.
    • The smart thing is to actually locate the pump at the right point down the hanger, so that the strainer can stay sticking out at a right angle, but near the bottom. This is the perpetual hassle with retrofitting any different pump to the factory hanger. Some just go where you need it to, some need fiddling and faffing, and modifying of stuff.
    • Some updates. After a lot of praying and some inspecting of crank threads, we've found that they were both kinda munted but nothing seemed terminal. The other option was drilling and helicoiling the crank. That is obviously the last option so we decided to at least try to get a OEM GM bolt in to GM Specs. So after honing/linishing the balancer from it's .002" interference fit to a .0018" to .0015" to .0013" it eventually slotted on to the crank. ATI state the interference is nominally 0.0007-0.0009... so it's still snugger than ATI reckon and explains the issues we had to fit the thing to begin with. New GM bolt went in at 37 ft/lb then torqued 140 degrees after which was EXTREMELY   but it tightened up to 140 degrees and it was a lot of force. So all things considered, the balancer is secured to the exact specs that GM want with the OEM Stretch bolt, (that ATI say you can use..) and the balancer itself is seated and snug AF. So WOO. Engine is now back in the car with lots of swearing. Bellhousing bolts done up, driver side manifold is on, AC Compressor and hard lines are back on the car. Next step will be to connect various engine bits/wiring/intake/radiator etc. Then oil and coolant and ... test start it? And of course, looking into this issue... which actually doesn't look so bad - It looks like it can be twisted back into shape with a set of multigrips. Anyone wanna buy my bonnet? Boy it looks good over there and sunk cost sucks.
    • Also this may be a stupid question, but how would you recommend getting the strainer on a downwards angle ? as they tend to obviously clip to the bottom of the pump which usually sits level 🥴
