Item: standard r34 side mount cooler
Age: 98 r34/10 years/60,000Ks
Condition: very good
Price: $170
To Fit: (What car) r23/33/34
Contact: post here/pm
thank you
Edited by R-SPEC
https://www.sau.com.au/forums/topic/215302-standard-r34-side-mount-cooler/
stolen from another thread ;)
R32
Length: 205mm Height: 190mm Width: 60mm Volume: 2337cm^3
R34
Length: 205mm Height: 220mm Width: 80mm Volume: 3608cm^3
Volume difference of 1271cm^3
Therefore;
R34 smic is 54% larger than the R32 smic (relative to the r32 cooler)
can you post a pic so i can see the condition of it?
any idea how much postage to Alice Springs, 0870 would be?
yeah, mum's can get a bit hot under the collar so a cooler might be the answer we've all been looking for......
Price: $170
thank you
y0 man is the smic still available? im interested of buying it...im located at melb as well. plz email me with your details coz i wanna pick up asap.My email is [email protected]. thnx
    • Is the 650rpm idle on the rb25det neo for stock cars only? I've never had my car before and after tuning it to idle at 650rpm when cold. Always idle's cold around 1100rpm, and then drops to about 900-950rpm. I've heard the r33 gtst's idle there.
    • Series 1 RB25DET 5 speed gearbox, push type, 1st and 2nd gear syncros worn, may need bearings. Comes with quick shift, Tomei gear knob, release fork, bearing carrier, master and slave cylinder. $850. Cusco Super Single clutch,assembly, 225mm, used, comes with a Direct Clutch solid centre 5 puck ceramic clutch plate. $290. RB26 cams used, excellent condition. $280. HDI GT2 intercooler, excellent condition, has 3 inch piping welded to inlet and outlet. $250. All items located in South Eastern Melbourne. Please PM me if interested.
    • Hi all, I’m currently running a str pipe hi low hks exhaust and downpipe. Was wondering if I change out muffler to a titanium one will it change the sound of the exhaust? Plus I have always liked the look of the titanium pipes … anyone have recommendations to one?    side note already have titanium intake pipes.
    • I looked up my other car that is a R33 GTST series 1.5. Anyone able to confirm what a Aero Form Bumper is?     (1G) 2 Door Coupe; (2GK + 11V) RB25DET; (4B) 2WD HICAS; (7F) 5 Speed Manual; (14G) Super Fine Hard Coat; (15U) Large Rear Spoiler + Aero Form Bumper + Rear Wiper (Aero Selection)
    • Ha ha, all good! I've almost caved in and realised I'm buying one.  I know myself well enough by now that I will start chasing ADHD butterflies half way through building it and not finish it so I'm better off spending the extra money buying one instead of making one just so I can get into straight away.  I would very much enjoy making one as fabrication is probably a strength and definitely a passion but I don't want that to be at the detriment to the car I'm ultimately building it for! There's some pretty good ones around for ~$1100 at the moment so I think I'll just go that way.  At the end I sell it or as mentioned, get another project to make further use of it! Thanks gents.
