  • Replies 41
Thats right they use english names as most common name and the one on the bank details will be the birth name.
They have been known to sell and not deliver many parts over the years. From Honda to nissans to rexys, I just thought Id put a notice out. .
Authorities said if I can show a few more people who have been scamed from this person, they will help. I now have a list building up..
david and jenny. hahah. who would look at an asian and think their name is david?
on topic though, i hate scam artists.
its bad enough buying something and getting the wrong thing by mistake, but when its deliberate, that shits me to tears.
Edited by ted180
Good work mate. I hope it all works out for ya's, and these dodgy buggers get ping'd
first i would try and find out what branch of the bank has that bsb number that gives you a rough area to work in as most people go to there nearest branch right ?.
then go to the electrol roll and punch in the initials and surname this is a free service in town and see if anything matches in the sourounding suburbs of the bank .
it's a long shot but it might help cheers
i always wanted to be a pi like magnum lol
10 m chau come up in the whitepages as well
ok after 5 mins of searching i reckon that bsb number belongs to the findon branch of bank s
another min of searching finds 1 m chau not saying its the right one tho in a suburb not very far away from the bank maybe a drive by to see if there is a wrx in the drivway bloody hell do some reasearch u want me to knock on the door for ya and ask lol
Edited by mid life crisis
Inspector gadget do do do do do do do DO DO. hahaha you nutter!
Seriously though, the authorities told you to publicly name & shame these folk before they will do anything about it???
sounds kinda dodge....
    • Are you suggesting that the kit did a cheap and nasty job of just jamming the wheel in between other things and caused the misalignment? I mean, we normally do this with an integrated crank trigger wheel, not something bodged on. It's not 1995 any more.
    • I mean, given the number of BMWs you own their tolerance for improper torque is rather low. The number of torque + angle spec bolts and non-reusable bolts in one is nuts.
    • Atmospheric vent requires something that doesn't use a MAF for load. You would need a standalone ECU for that.
    • Hey all,   I’ve got an RB25 with a trigger kit that includes a crank wheel, and I’ve hit a wall trying to sort a timing belt tracking issue. The belt either rides right on the edge of the cam/crank pulleys or walks slightly forward once the engine starts. It tracks okay-ish for a moment, then creeps right to the edge—and honestly, it’s stressing me out.   I’ve spent hours removing and reinstalling the belt, double-checking everything:   Tensioner setup is good, checked multiple times Idler pulley and washers are all in the correct places Followed the RB25 timing procedure step-by-step     The only thing I changed was the rear crank washer—I swapped the OEM one for a Neato version, and it made things worse. The belt now sits even more forward than before. I’m beginning to think the crank trigger wheel itself (from the trigger kit) is the issue—poor design or slightly off dimensions.   What’s strange is that with the previous belt setup, it actually ran fine for a couple of years—around 4,000 to 5,000 miles, even with hard driving and high RPMs. But even then, the belt was always riding right on the edge, and I know that’s not ideal or safe long term.   At this point, I’m debating whether to:   Machine a few mm off the crank trigger wheel to bring it back in line, or Replace it entirely with a better-designed unit     Only thing is, I already have the Cherry Hall sensors, bracket, etc.—I just want to replace the wheel only, not the entire kit. Anyone know a brand or supplier that sells just the crank trigger wheel on its own?   Would really appreciate any feedback—especially from anyone who’s run into this exact issue and found a reliable fix.   Thanks in advance.
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
