hey everyone
i have a Nissan skyline R32 GTS-t 1992 , it has 80 k on the body but the engine was changed by the guy i bought the car from. i did a compression test today as i was just changing the radiator hosing.
these are the scores i received
Cylinder
1-125
2-135
3-125
4-126
5-126
6-139
i wasn’t sure what the rb20det should be getting however , i was thinking some where about 160, would someone be able to let me know what i should be receiving? also how bad are my scores? if scores are bad, is it worth putting a rb25det? Instead of (if expensive) fixing the rb20det.
Thanks any help appreciated
niran
Edited by niran
https://www.sau.com.au/forums/topic/215335-compression-test/
There are 2 ways to look at it...one is that the overall figure is rather low...even for the rb20 which runs lower compression...another way to look at it is that the variation between the cylinders is not too big so its not too bad...
I'd get it checked again with another compression gauge and then go from there...comp gauges can very very inconsistant...my guess though is that it might be quite tired...
a mate of mines rb20(170,000k's) returnd 110 across all 6 on a comp test(snap on comp tester)... his motor has copped an absolute caining.. we havent been able to kill it yet its not so much about the reading as for some reason all the comp testers ive used have returned different results compared to others
you also have to remember an rb20 has very small stroke/bore dont expect it to have similar compression on the tester compared to a rb25/26 or a 30 mainly look at how even it is across the motor.. but in saying dont pay to much attention to the pressure reading.. if you havent got 3 didgets as the read out.. it might be something to look into
thats my thoughts anyway..
True thanks for that man.
i went to kyp today they said for a half cut with a rb25det, gear box, and tail shaft and so on will come to $2000.00-$2500.00. i was thinking wether to do that or what would you guys reckon if i re built the RB20DET with aftermarket internals as it would probably come around the same price.. any way let us know what you guys think.. Wether i should ( once this engine dies) go and do the rb25det conversion or re build the rb20det?
thanks every one
niran
hey mate when i bought my 32 GTS4 '93 i got a comp test done on it b4 i bought it..The odo read 97,000kms but who knows how tru that is.. any way i got 155 across all cylinders which the mechanic said its pretty good...i also did a leak down test and got 8% across all cylinders which he said is very good too. hope this helps
  • 1 year later...
Wow this is an old post i never checked it until now, dw that was when i was a bit immature. The rb20 is still going strong but I’ve been doing some research in comparison into the rb20 vs rb25 like 2 quick said the rb20 shows great results in strength specially as the rods are shorter and also the engine can rev out a big higher..
However the rb25 can spool bigger turbo’s and get bit more power out off it compared to what the rb20 can. I’m still in the process of really deciding guess I’ll keep on reading and keep asking people on this forum what they would choose and why..
Thanks guys
Niran
Thanks guys
Niran
RB20 rods are longer than RB25/26.
Cheers
Gary
