Hey guys,
Had a idea that I got from an autospeed article not long ago.
I have noticed my intercooler piping is 2.5" and I have a FMIC, so the piping runs back across the front of the radiator, then back over the engine. I have touched the piping three times after going for good drives, in coolish weather, and noticed that once the piping gets into the engine bay, it turn HOT, so hot that you can't leave your hand on it for more than 5 seconds, which is bad for performance.
I have also noticed a beer/stubbie cooler would fit almost perfectly over 2.5" piping.
I'm thinking of buying approx. 10-12 of these and shoving them over the cooler pipes, total cost ~20-25 bucks.
Thoughts everyone???
Fixxxer
Edited by Fixxxer
https://www.sau.com.au/forums/topic/215367-insulating-intercooler-pipes/
  • Replies 51
Posted Images
I'd be interested to see the amount of heat that the air actually takes on.
After cooler (take temp), Before Throttle body (take temp)
Think about how fast its moving through there when your on the song. I cant imagine it taking on a massive amount of heat.
This has come up before a few times I think, no real results as yet though
Make sure they don't get minced by the radiator fan blades, some peoples intercooler setups that pipe is pretty close. I have had to help a mate dremel the corners of his fan blades off to clear the intercooler piping before, i have read something on autospeed about putting rubber over mits over intercooler piping too. That wouldn't be as cost effective as your stubbie cooler cooler.
The oven mits is autospeed's idea, except theirs looked even dodgier, and cost them $75 for 2 oven mits which was only enough to cover 40cm of pipe. I expect beer coolers to give similar results for way less $$.
Ohh and R31Nismoid - On the autospeed article, the guy got a 7-10 C drop in temps from insulating approx. 40cm of pipe. I'm expecting about 1.0 - 1.2m. I agree that at full throttle the air speed is massive, and temp increase may be smaller, but it can't hurt right?
I'm really looking to improve the on throttle response and pickup throughout the rev range, when air speed is reduced, part throttle, etc...
Fixxxer
should make some difference, I think.
if intercooler water spray is a good idea, then probably so is this.
would look pretty rangi but for the price you pay, you can't go wrong eh.
actually hot intercooler piping is a main reason im going front facing plenum. only a meter or so of the pipes will be in the engine bay.
Edited by sonoramicommando
Fixxxer
Ah ok cool, they had some numbers, great stuff!
What car/setup was it?
Where were the readings taken? (like, off idle, cruising, full throttle etc)
Sounds interesting :banana:
i wonder how heat/fire proof a stubbie holder is.
last thing you want is for it to catch fire.
if it is stable under hot temps, it sounds like a pretty good idea. and considering you could likely get a snug fit passing it over the cooler piping, it wouldnt look too bad either.
Edited by Munkyb0y
this is an interesting concept i also would like to see some results, however i am going to the road of changing my piping from the radiator/hypbrid style to suit my greddy intake plenum (not currently on car) cheers.
i just did a small test. i got a stubbie holder, and placed an open flame directly under it, with my finger firmly against the other side. it insulated the heat perfectly. i couldnt feel the flame at all.
unfortunately it caught fire. so then i tried it again with the flame about 1 inch away, and it caught fire again in about 20 seconds. this might pose a problem. it seems this stubbie holder is basically foam inside, and this starts to melt like rubber and then catches fire.
are there different types of stubbie holders?
Edited by Munkyb0y
yeah thats obvious. but extended periods exposed to heat wasnt a test option :blink: . so open flame is a worst case scenario, and may also simulate to a degree what long periods of heat might do. ie. cause the material to become brittle, hard, melt, crack etc.
Edited by Munkyb0y
Yes, I've thought about the whole catch on fire thing. Looking at where they will be positioned on the cooler piping, I would guess that underbonnet temp, and the actual temps of the intercooler piping to be less than 100C, which I wouldn't imagine to be anywhere near enough heat to make these things smoke, let alone catch fire.... I was going to trial a few first though, maybe chuck em in the oven at 100C? See if they dry out..... etc....
I'm going to go ahead and buy them anyways, if it fails for whatever reason, I have many coolers to keep my beers cold :blink:
Fixxxer.
excellent :thumbsup: will be watching for your results.
if they survive the 100c test, maybe bump it up to 150c or so. just for peace of mind :)
i can vouch for one thing, it certainly insulates well from heat.
Edited by Munkyb0y
Let's do some numbers on say an R33GTST running 1 bar of boost at 2,000 rpm
2.5 litres x 2 bar (1 bar atmo + 1 bar boost) x 2,000 rpm /2 (it's a 4 stroke) = 5,000 litres per minute or 83 litres per second
The average intercooler pipework (after the intercooler) holds around 6 litres.
So the air spends around 0.07 of second going though the pipework.
Now touch the pipework with your finger for 0.07 of a second and see how much heat transfer there is.
Nothing, zero, zip, diddly squat ....... because the contact time isn't enough to transfer any heat.
But wait there's more.....not all of the air is touching the inside of the pipework, some goes down the middle (boundary layer not withstanding).....so its even less than nothing, zero, zip and diddly squat.
That's at 2,000 rpm, at 5,000 rpm it's all of 0.03 of second.
So make your own judgement as to whether or not your time (and money) would be better spent elsewhere.
Cheers
Gary
Hmmm, Sydney Kid poses an interesting case. Numbers speak.
If this mod can be tested and yield some actual numbers saying it's worth it, then you win. I'd say heatsoak would definitely be reduced with this mod, in the way there's a small amount of foam glued to the back of a SMIC.
If you test this and it works, i'll be buying a dozen stubbie holders with my next case :thumbsup:
someone else brought up this point before - without the figures.
does it mean intercooler heatsoak is not an issue either?
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
